IAP 345 not upgrading with other APs during Cluster Firmware Upgrade
  • 1.  IAP 345 not upgrading with other APs during Cluster Firmware Upgrade
    Posted 29 days ago
    When we run the upgrade the Aruba model 345 APs fail to upgrade and form their own cluster with their own master. We end up having constant bouncing between the upgraded and the not upgraded.
    As part of the Cluster we have various AP models that include AP 305, 505, 375, 575.  Only the AP 345 models fail to upgrade with the others.
    I started up the wifi with only the Aruba 345 APs
    searched for the available firmware and it showed the latest
    ran the upgrade and everything went through - right down to the reboot.
    when the APs came back online they were still running the old firmware -  (Digitally Signed - Production Build)!
    Any suggestions?
    IAP 345 models will not Upgrade with other Cluster Ap's
  • 2.  RE: IAP 345 not upgrading with other APs during Cluster Firmware Upgrade
    Posted 29 days ago
    thats strange cause for mixed AP model instant cluster only the AP that is the VC will upgrade all the rest of the APs that are the same model and the rest of the other AP models would not be upgraded.
    I suggest to put the IAP-345s in a different VLAN, then upgrade them to the same firmware version as the rest and finally add them to the same VLAN to form a cluster.
  • 3.  RE: IAP 345 not upgrading with other APs during Cluster Firmware Upgrade
    Posted 29 days ago
    The AP-345 cannot be upgraded beyond 8.10.x (see compatibility matrix here).
    If you have a mixed cluster, all APs should be on the same firmware version, which means that they need to have a version that is supported on each AP type.
    It may be confusing that the automatic update offers 8.12, but it won't work.
  • 4.  RE: IAP 345 not upgrading with other APs during Cluster Firmware Upgrade
    Posted 29 days ago
    AP-345 use the same platform name Draco as the newer AP-518 and  you get this option. Unfortunately as Herman already wrote, AP-34x is not supported beyond 8.10. version.
    It is worth consulting supported platform table in a Release Notes to see, if all AP models are supported with desired version.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
