IAP LDAP integration
  • 1.  IAP LDAP integration
    Posted May 26, 2024 07:07 AM
    Dears,
    Does anyone know,
    Does the AP-635 support the LDAP integration When works as IAP?
  • 2.  RE: IAP LDAP integration
    Posted 30 days ago
    LDAP is authentication is supported with Instant APs. here is the reference from the user guide.
  • 3.  RE: IAP LDAP integration
    Posted 29 days ago
    Please note that if you intend to use 802.1X or WPA2-Enterprise, either RADIUS or RadSec is probably needed. LDAP has a limited scope, similar as TACACS.
    You may need to work with your Aruba partner to properly design your network and security.
