IAP Virtual controller feature.
  • 1.  IAP Virtual controller feature.
    Posted Aug 03, 2022 04:40 AM
    Hello Everyone,
    Can anyone help me to know that, how many Instant Access Point can be taken in a single cluster ?
    I have seen one article which is saying around 128 IAPs in a cluster, but that article is published in 2017. Is there any update on that ?
    Thank you in advance.
    Sandesh S Zade.
  • 2.  RE: IAP Virtual controller feature.
    Posted Aug 03, 2022 06:10 AM
    If you want to setup a WLAN network  (without overlay) beyond 128 APs you can migrate to AOS10 (supported for 3xx, 5xx APs). AOS10 is supported in Central.
  • 3.  RE: IAP Virtual controller feature.
    Posted Aug 03, 2022 06:54 PM
    Yes still the recommendation for Instant cluster is 128x IAPs.
    if you need more than 128x IAPs in a cluster, you can either have more than clusters or Sietze has suggested go with AOS10
    Here is more info on AOS10
    https://www.arubanetworks.com/techdocs/AOS10_3_OLH/Content/aos10x/aos10_home.htm
