There seems to be a fair number of posts on Airprint but I cannot seem to find a resolution or changes to settings that helps.
We have a simple setup that we are trying to get Airprint to work on with less than a dozen APs (as noted in subject) running controllerless on Instant and a Airprint compatible printer to be used for mobile printing. Access is only needed on 1x SSID and there are not multiple VLANS to worry about. The Apple protocols have been enabled and inter-user bridging is NOT blocked.
The symptoms are confirmed as follows...
IF the printer AND IOS device are on the same AP, everything works flawlessly.
But as soon as one, or the other, picks up on a different AP - all too easy - no printer can be found.
If the printer and mobile devices are moved to BOTH be on a different AP, once again everything works great.
Note - I do not know if this type of an issue has been resolved with any firmware updates. We are due to do so. Comments related to Airprint problems in general seem to spread themselves over various firmware releases.
Any pointers on what may block the Airprint service from working BETWEEN APs but yet work well when connected to the same AP?
Keep it simple if possible, please! : ))))
