Hi Karsten,
if you are not using IMC to manage VMWare hosts and VMs, you could stop the imvvnmdm.exe process and set it to manual start. This should not affect the rest of IMC. Please open a support case if you need the problem investigated and fixed.
Kind Regards
Paola
Kind Regards
Paola
Original Message:
Sent: Mar 21, 2023 11:14 AM
Subject: IMC - high utilization of imcvnmdm.exe
I'm running HPE IMC Standard Edition (E0708) on a Windows Server 2022 in VMware. I've got the problem that the cpu utilization is 100% caused by the imcvnmdm.exe. Whe I kill the process, everything is fine for a while, but after one or more days the effect comes back.
The problem also occured on an Windows Server 2012, which I used until one february. I also tried to install E0708P02, but I switched back, bacause of the problem with the LDAP-Authentication.
