Hello there,
have you tried to load a .bin file instead of .ipe?
To check exactly what happened you can enable debugging on the imcupgdm process in iMC .In Web Gui use System-System configuration-Log configuration find the imcupgdm and put it on debug . Than you can test upgrade to both switches and check the log .It will show you detaied information .
You can also check the logbuffer of the switch to see if it got any request from iMC server and where it exactly fails.
I aslo recommend you to check if there is enough space on all stack members flash to upload the image.
Hope this will help you further.
Marina
HPE
Sofia
Original Message:
Sent: Jul 08, 2022 06:11 AM
Subject: IMC issue upgrading switches
Hi there,
I have carried out a good few upgrades of switches via IMC. However, I have just had some issues. I have tried upgrading both 5510 & 5130 switches and have been getting error "device cannot recognise the uplodaed device software. Can anyone here help. I have tried troubleshooting the obvious, SNMP/SFTP SSH etc all are ok. Also, I have syncronized the switches a couple of times just in case that was the issue. I have attached the errors below.
I look forward to your response?
Kind regards
