Hi, I don't know if you have unique SNMP secrets per device. If yes, and you've established the switch receives the snmp, check with strings that don't contain non letter values. Early in we had an issue where switch was hält with the strings but IMC wasn't.
You can test snmp connectivity using a linux machine using a command like below
snmpget -v3 -l authPriv -u USER -a MD5 -A PASSWORD -x AES -X SECRET teststack 1.3.6.1.4.1.25506.2.91.1.2.0
Original Message:
Sent: Jan 04, 2023 09:56 PM
Subject: IMC not connecting with Switch 8206zl (HP J9477A ) SNMPv2/v3
Other Aruba switches are working fine with SNMPv3. Only this 8206zl switch is not working with SNMPv3. Suspecting ACL or routing might be the issue. I am not sure where to start looking
Any help?
What I tried to fix
- Updated the latest firmware,
- try to re-setup SNMPv3
my switch config snmpv3
snmp-server community "XXXiv" manager unrestricted
snmp-server community "BBBib" operator
snmpv3 enable
snmpv3 restricted-access
snmpv3 group managerpriv user "BBBIT" sec-model ver3
snmpv3 user "BBBIT"
