Network Management
IMC upgrade problem (E0708P03 --> E0710)
This thread has been viewed 30 times
  • 1.  IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 09, 2024 01:45 PM
    I would like to upgrade my IMC from E0708P03 to E0710 but i have a problem that occurs during wizard upgrade with this message "Do not install (The dependence has not been installed. Right-click to view dependency information.)
    My IMC server is under Windows server 2012 R2 and there is a local database under microsoft sql server 2008.
    Has anyone ever had this problem ?
    Thks
  • 2.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 03:40 AM
    have you uninstalled/not upgraded some components to 708P03 so they are  not present/the wrong version?
    Using 'show dependencies', ensure all the listed components are installed and upgraded to 708P03.
    Kind Regards
    Paola
  • 3.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 04:14 AM
    Also please update the database to a supported version before you try the upgrade again.  2008 is no longer supported and the upgrade may render the installation unusable as documented in the readme.
    Kind Regards
    Paola
  • 4.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 04:19 AM
    Usually I update the version with IDMA but here is what I have in the monitor tab (the last update that worked was E0708P03) :
  • 5.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 10, 2024 05:43 AM
    the components and versions are fine, please upgrade the database, maybe it's just the wrong error for the unsupported database version
    Kind Regards
    Paola
  • 6.  RE: IMC upgrade problem (E0708P03 --> E0710)
    Posted Apr 11, 2024 06:48 AM
    Ultimately the problem was the database version. I migrated to a new windows server and no more problems. THANKS
