Impossible to connect from iap web ui
This thread has been viewed 24 times
  • 1.  Impossible to connect from iap web ui
    Posted 17 days ago
    Hello, it is impossible to connect to the administration interface of my AP-505 when I am not actually next to it. Is there a special configuration to allow connection to the terminals? Do I have to connect in admin mode from the 5GHZ frequency band?
    Do you have an idea?
  • 2.  RE: Impossible to connect from iap web ui
    Posted 14 days ago
    Hi Vincen.
    If you didn't explicitly blocked it in firewall rules or in role settings, there should be no problem connecting to the APs GUI interface from wired or wireless network.
    Check on SSID role settings or your user role settings if you have a rile like this or similar.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
