Insight DB issue
This thread has been viewed 53 times
  • 1.  Insight DB issue
    Posted Dec 21, 2022 11:42 AM
    Customer has 2 Clearpass servers in a cluster and tried to set up an enforcement policy that uses the Insight database as an authorisation source. The insight database is running on the subscriber. The lookup to Insight appears as if it is failing as I see this alert in all authentications that are using this service:
    Session failed for Host=10.24.0.24, Reason=[Failed to connect to datasource: [unixODBC]FATAL: password authentication failed for user "appexternal"
    FATAL: no pg_hba.conf entry for host "10.26.0.23", user "appexternal", database "insightdb", SSL off
    SQLState=08001 ErrorCode=101].
    Session failed for Host=10.26.0.23, Reason=[Failed to connect to datasource: [unixODBC]FATAL: password authentication failed for user "appexternal"
    I have changed the real IP addresses but in this case 10.24.0.24 is the subscriber running Insight. 10.26.0.23 is the publisher
    I understand that there is an 'appexternal' database account but I thought this was for databases that are external to the cluster so I should not need to change this.
    Additionally, in the event viewer, starting about 1 week ago I see this warning every minute:
    Unable to communicate with database 10.24.0.24
    and
    Unable to communicate with database 10.26.0.23
    Is there anything I can do before calling TAC?
    Stewart Smith
    ACMX, ACDX, ACCP, ACSA
  • 2.  RE: Insight DB issue
    Posted Dec 22, 2022 04:29 AM
    You may try to set the appexternal database password and see if that resolves the issue. If you use appexternal, you probably can just set it it to what is already is. The appexternal password is set under the Server Managers, Cluster Wide Options, Database.
    As well under Authentication Sources -> Insight Repository, you should set the password (to my surprise it's also configured there, and it does use the appexternal account).
  • 3.  RE: Insight DB issue
    Posted Jan 05, 2023 05:42 AM
    Sorry for delay on coming back on this.
    We exported the configuration from the Auth source for the Insight DB which included the password. We then applied this same password under the server manager, cluster wide config. When saving, the config reported no changes made so the passwords already match.
    Stewart Smith
  • 4.  RE: Insight DB issue
    Posted Jan 06, 2023 03:54 AM
    Ok so we fixed this. The password set for 'appexternal' contained special characters. After checking here: https://www.arubanetworks.com/techdocs/ClearPass/6.10/PolicyManager/Content/CPPM_UserGuide/Insight/Overview.htm - There is a section that shows allowed special characters for passwords used in all Clearpass modules. We could see that two of the characters were not allowed so we changed them to ones that are shown as allowed - a '?' and a '+' but this still did not work. We removed all special characters and the connectivity now works
    It should be noted that we have never previously set or changed this password. We are running version 6.10.7
    Stewart Smith
  • 5.  RE: Insight DB issue
    Posted Jul 08, 2024 01:18 PM
    Thread is a little old but we just migrated to from 6.10 to 6.11. It seems the insightdb is no longer on the new platform. Or is just located within the tipsdb now. Only issue is appexternal no longer has access.
    Our "FleetMGMT" software integrated with this to show where devices are in the district.
    Use to connect to
    DB: insightdb
    Table: public.endpoints
    Is there anyway to query to get
    User, MAC, AP,timestamp?
  • 6.  RE: Insight DB issue
    Posted Jul 09, 2024 04:30 AM
    In ClearPass 6.11, the database for Insight has been separated from the configuration database to improve synchronization (and segmentation of data).
    Try connecting to SQL port 5433 (Insight/TipsLogDb) instead of the default PostgreSQL port 5432 (tipsDb).
  • 7.  RE: Insight DB issue
    Posted Jul 16, 2024 08:38 AM
    Awesome Thanks !!!!!!!
