Wired Intelligent Edge
Insurmountable compatibility MacSec IEEE 802.1AE problems AOS Switch to AOS-CX Switch
  • 1.  Insurmountable compatibility MacSec IEEE 802.1AE problems AOS Switch to AOS-CX Switch
    Posted Jan 18, 2024 06:27 AM
    Please advice, anyone with working switches ?
    Steinar
  • 2.  RE: Insurmountable compatibility MacSec IEEE 802.1AE problems AOS Switch to AOS-CX Switch
    Posted Jan 22, 2024 11:07 AM
    From CX manual:
    Specifies the CKN (Connectivity Association Key Name). Range: 1 to 64 hexadecimal characters
    Specifies the CAK (Connectivity Association Key) in plaintext. Range: 1 to 64 hexadecimal characters.
    AOS:
    Enter the CKN as a string of hexadecimal digits up to 32 characters long
    Enter the CAK as a string of hexadecimal digits up to 64 characters long
    This mean that for the AOS the CAK limitation is 32 byte ascii/characters
    • Bee aware some other setting smay be accepted, during input.
    ie, a 34 characters ascii CAK will be silent truncated....to 32 characters
    ie.:
    12345678901234567890123456789012
    and
    1234567890123456789012345678901234
    will both work, in AOS >< CX MacSec (on AOS side)
    as
    on CX side will
    • So: stay with CKN/CAK 32/32 ascii/characters. (digits and letters)
    Steinar
  • 3.  RE: Insurmountable compatibility MacSec IEEE 802.1AE problems AOS Switch to AOS-CX Switch
    Posted 23 days ago
    Hi Steinar,
    I had the same problem.
    Adjusting the key server priority solved it for me.
    The AOS switch must be the key server.
    In my case, the AOS had a priority of 16 (show port-access mka status)
    (The default prio of the AOS-CX is 0)
    So I gave the AOS-CX the maximum priority of 255 (key-server-priority 255 (on the mka policy context))
    Best regards
    Robin
