Hi all
I have a number of users reporting slowness on their PCs'. They are all connected to a A3100-24-PoE v2 EI running 5213P08 - I think it's the latest that was released for this switch.
I have noticed that there are high number of output errors and a matching number of aborts.
Is it correct to assume if the errors are in output direction this would indicate an issue on the switch end ?
I have also noticed when I hardcode duplex and speed on the interfaces the situation changes in a way that there are no more output errors but input error counter gets populated, that include CRC which weren't present in output direction.
below is with duplex and speed hardcoded
84 CRC, 66 frame, - overruns, 1194 aborts
- ignored, - parity errors
This is one is with speed and duplex set to auto., output and aborts are always matched. Also the count goes much higher, the below is just seconds after I cleared the counters
Output: 17 output errors, - underruns, - buffer failures
17 aborts, 0 deferred, 0 collisions, 0 late collisions
