Network Management
last person joined: 9 hours ago
interface mgmt
  • 1.  interface mgmt
    Posted Mar 26, 2024 05:06 PM
    Doc says I should use interface mgmt to configure IP for ssh/https. CMD invalid input mgmt. Also, why does this forum not have a search function? I know this issue has to have been addressed many times since the docs are not accurate.
  • 2.  RE: interface mgmt
    Posted Mar 26, 2024 05:34 PM
    What equipment model?
    There is a native search tool - top right hand corner, orange magnifying glass.
    These forms can also be successfully queries using Google as well.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: interface mgmt
    Posted 30 days ago
    6000 24G Class4 PoE 4SFP 370W Switch
    DT-Retread# show running-config
    Current configuration:
    !Version ArubaOS-CX PL.10.08.1010
    !export-password: default
    hostname DT-Retread
    user admin group administrators password ciphertext *****************4+fpD1RqjBGbNk2K+WK9OzTS2pX
    ntp server pool.ntp.org minpoll 4 maxpoll 4 iburst
    ntp enable
    ssh server vrf default
    vlan 1
    vlan 2
        voice
    vlan 3-5
    spanning-tree
    interface 1/1/1
        no shutdown
        vlan trunk native 1
     -- MORE --, next page: Space, next line: Enter, quit: q        vlan trunk allowed all
    interface 1/1/2
        no shutdown
        vlan trunk native 1
    interface 1/1/3
        no shutdown
        vlan trunk native 1
    interface 1/1/4
        no shutdown
        vlan trunk native 1
    interface 1/1/5
        no shutdown
        vlan trunk native 1
    interface 1/1/6
        no shutdown
        vlan trunk native 1
    interface 1/1/7
        no shutdown
     -- MORE --, next page: Space, next line: Enter, quit: q        vlan trunk native 1
    interface 1/1/8
        no shutdown
        vlan trunk native 1
    interface 1/1/9
        no shutdown
        vlan trunk native 1
    interface 1/1/10
        no shutdown
        vlan trunk native 1
    interface 1/1/11
        no shutdown
        vlan trunk native 1
    interface 1/1/12
        no shutdown
        vlan trunk native 1
    interface 1/1/13
     -- MORE --, next page: Space, next line: Enter, quit: q        no shutdown
        vlan trunk native 1
    interface 1/1/14
        no shutdown
        vlan trunk native 1
    interface 1/1/15
        no shutdown
        vlan trunk native 1
    interface 1/1/16
        no shutdown
        vlan trunk native 1
    interface 1/1/17
        no shutdown
        vlan trunk native 1
    interface 1/1/18
        no shutdown
        vlan trunk native 1
     -- MORE --, next page: Space, next line: Enter, quit: q        interface 1/1/19
        no shutdown
        vlan trunk native 1
    interface 1/1/20
        no shutdown
        vlan trunk native 1
    interface 1/1/21
        no shutdown
        vlan trunk native 1
    interface 1/1/22
        no shutdown
        vlan trunk native 1
    interface 1/1/23
        no shutdown
        vlan trunk native 1
    interface 1/1/24
        no shutdown
        vlan trunk native 1
    interface 1/1/25
        no shutdown
        vlan trunk native 1
    interface 1/1/26
        no shutdown
        vlan trunk native 1
    interface 1/1/27
        no shutdown
        vlan trunk native 1
    interface 1/1/28
        no shutdown
        vlan trunk native 1
    interface vlan 1
        ip address 192.168.120.15/24
        no ip dhcp
     -- MORE --, next page: Space, next line: Enter, quit: q        !
    https-server vrf default
       DT-Retread#                                                           exit
  • 4.  RE: interface mgmt
    Posted 30 days ago
    Aruba CX 6000 series switches do not have dedicated management interfaces.
    Management for these switches would use your Layer3 VLAN Interface IP (SVI)
    Zak Chalupka
    wifizak@hpe.com
  • 5.  RE: interface mgmt
    Posted 30 days ago
    We are only using it as an L2 switch. Going from procure to this is going to be a challenge I guess.  Seems like I should be able to access it https/ssh via 192.168.120.15. I cannot. I also have no arp entries even though I am in the same vlan and have internet access. I cannot ping the SonicWall gateway or the switch. Very odd.
  • 6.  RE: interface mgmt
    Posted 30 days ago
    You may have a port VLAN configuration issue in that case.
    The 6000 switch is an L2 switch. You would not use it to route user/production traffic, that SVI is for management only.
    There would be no ARP entries on the switch in this topology. Do you see MAC's in the table for VLAN 1 on that switch? Can you ping something on VLAN1 from that switch?
    Zak Chalupka
    wifizak@hpe.com
  • 7.  RE: interface mgmt
    Posted 29 days ago
    Found the issue. Made typo when setting up the firewall. It was supposed to be 192.168.120.1  . What it was 192.168.20.1 .  The switch is fine and the config is working. Sorry
