Hi ITSubs,
to enable inter-vlan routing on your 3800 switch you can simply add the
"ip routing" command.
As for the trunks between the 18XX and 3800 switches you need to pick appropriate interfaces to have matching speeds, if you are going to use SFPs or DACs these have to be supported by the switches etc.
For the configuration you would have to use the Web GUI on the 18XX switches, because these are web managed devices. The 3800 can be configured either via CLI or Web GUI.
The command to configure a trunk via CLI is "
trunk <interface-list> trk1 lacp" or in the "
Trunks" menu of the switch's web gui.
I'm also linking some resources you might find useful:
Aruba Basic Operation Guide for the 3800 switch:https://support.hpe.com/hpesc/public/docDisplay?docId=a00108367en_usAruba Support Portal(ASP) where you can find all available documentation and software for your Aruba switches:
https://asp.arubanetworks.com/downloads;sort=VERSION_DESC;fileTypes=DOCUMENT;products=Aruba%20Switches;productSeries=Aruba%203800%20Switch%20Series;fileContents=User%20GuideHTH,
Toni
Original Message:
Sent: Jun 27, 2022 04:06 PM
Subject: InterVLAN routing help
Hello all,
I'm new to VLAN world and looking for some help with inter VLAN routing.
I have a HP e3800 switch, which has a few VLANs setup:
VLAN10 10.10.10.10 /24VLAN20 10.10.20.10 /24VLAN30 10.10.30.10 /24VLAN40 10.10.40.10 /24VLAN50 10.10.50.10 /24VLAN60 10.10.60.10 /24VLAN90 10.10.90.10 /24
We'll use .10.0 /24 as the 'management' network, while the other VLANs will have various class of endpoints.
This switch is connected, via LACP trunk, to a firewall which is the default (internet) gateway.
I'd like to understand how to configure the switch for inter VLAN routing and also the LACP trunk to the firewall.
The switch can also be the DHCP server.
We also have a couple of HP 1820 access switches which will be connected to the e3800 via LACP trunks; these switches is where most endpoints will connect to.
So I need to understand how to configure the LACP trunk between e3800 and the 1820 access switches.
I have done some basic setup on the e3800 - creating VLAN interfaces and assigning IPs.
Your assistance is greatly appreciated! Thank you kindly.
