iOS devices not join hidden SSID MPSK
  • 1.  iOS devices not join hidden SSID MPSK
    Posted Mar 26, 2024 01:07 PM
    hello,  when I hidden the SSID  MPSK  with MPSK groups and device registration, the new devices registered not join the network.
    If the ssid is visible magically the devices connect,
    devices are: Ipad mini (6th generation)  Ios 17.2
    I can't see nothing no client mac address in clearpass and also in the wifi controller logs
    have you already esperienced this?
    ACMP ACSP ACCP ACEP ACDP
  • 2.  RE: iOS devices not join hidden SSID MPSK
    Posted Mar 26, 2024 03:49 PM
    Don't hide SSIDs.  Some devices, and specifically Apple devices, don't like hidden SSIDs when used in conjunction with DFS channels.  In general, hidden SSIDs just cause problems and complicate roaming.  Don't hide SSIDs.  There is zero benefit.
    Carson Hulcher, ACEX#110
