As far as I know, the ip default-gateway is used in non-ip routing mode; the ip route 0.0.0.0/0 is used in routing mode.
With routing mode enabled, I think you can remove the ip default-gateway as it is not used. It won't hurt either, but may be confusing when someone reads the config, so probably better to take it out.
Original Message:
Sent: Sep 21, 2022 12:51 PM
Subject: IP Route and IP Default Gateway configured on same switch
Is it an issue to have an IP route and IP DGW setup on the same switch?
I have layer 3 routing setup with RIP enabled. Will there be a conflict, and do in need to remove the DGW?
Ip default-gateway 10.0.0.1
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip routing
snmp-server community "public" unrestricted
oobm
ip address dhcp-bootp
exit
router rip
redistribute connected
enable
exit
