Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
This thread has been viewed 24 times
  • 1.  Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
    Posted May 25, 2022 09:20 AM
    Dear Community,
    I am trying to upgrade an AP 305 without great success.
    Is there a tutorial where this procedure is explained?
    Thank you.
    Best Regards.
    Domenico De Felice
  • 2.  RE: Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
    Posted May 25, 2022 02:23 PM
    If it is an AP-305 (not an IAP 305), the access point will upgrade before it joins the controller.
  • 3.  RE: Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
    Posted May 26, 2022 02:19 AM
    Thank you for your reply.
    How Can i check if this AP is IAP?
    The model is APIN0305
    Domenico De Felice
  • 4.  RE: Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
    Posted May 26, 2022 07:52 AM
    On the back of the access point should be a sticker with a barcode that either says IAP-305 or AP-305
  • 5.  RE: Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
    Posted May 26, 2022 07:59 AM
    Thank you.
    The device they can sure be upgraded because I found one that has been switch to controller mode...
    The problem is that I don't know how they did it.
    I tried to reset an AP but I am having issue, it is seen by the controller but when I tried to do the provisioning it says that the firmware is not updated....
    Then, it showing instability like going up and down.
    I think the only way is access with console cable right?
    Because the AP looks inaccessble via web interface, telnet or ssh...
    Domenico De Felice
  • 6.  RE: Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
    Posted May 26, 2022 10:10 AM
    On the controller, type "show log system 50" to see if you see any messages about that access point.
  • 7.  RE: Is there a way to upgrade the firmware of an aruba Ap 305 connected to a controller?
    Posted May 27, 2022 05:26 AM
    HI,
    I did that, I can see a lot of this errors:
    <5662> <ERRS> istml An internal system error has occurred at file sapm_ap_mgmt.c. function sapm_get_img_build_version
    I cannot see any error for the APs
    Domenico De Felice
