From this post: "dirty" typically means that some ports between the AP and the controller are blocked, whether it be GRE or papi (udp 8211)."
And some troubleshooting guidance for APs with a dirty-flag in this knowledgebase article.
Original Message:
Sent: Feb 21, 2024 05:07 AM
Subject: Issues with release 8.10.0.10 with dirty AP's
Upgraded a cluster of 2x 7210 controllers & virtual mobility conductor from 8.6.0.20 to 8.10.0.10 .
I upgraded already before some clients to 8.10 without any issues.
But this time is the first time to 8.10.0.10 and my AP's come up in 2SID when mine controller is cluster.
Before I hadn't any issue and everything was working fine on 8.6 .
When running on 1 controller everything is working fine. Even if I switch to the other controller.
So connection to AP's should be fine.
My cluster is L2 conntected and verified, already removed the cluster config and re-applied but without succes.
Does anyone have the same problems with version 8.10.0.10 or where must I look?
I opened already a TAC case.
