License issue
This thread has been viewed 33 times
  • 1.  License issue
    Posted Jan 17, 2023 02:44 PM
    I have 160 2 part wids/wips license, meaning they are AP and RFprotect, I have a new single 7240xm, since licensing is in a centralized single pool how can I use these License for a wid ? I also have AP license that are 3 part, AP, PEF and RFprotect.  Licensing would be easier if I could create my own pools, such as a Wid/Whip pool and an AP pool since wid/wip license are cheaper.
  • 2.  RE: License issue
    MVP GURU
    Posted Jan 18, 2023 09:24 AM
    You would still need to use an AP license along with the WIDs/WIPs. Is this an AOSv8 environment managed by a Mobility Conductor?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: License issue
    Posted Jan 18, 2023 09:53 AM
    Appreciate if any one can help with the article for configuration of wips and testing of wips to make sure whether it is configured properly or not .
    And collection of logs to see the evidence of rogue APs .
    Appreciate immediate response.
    Thanks in advance...
    Best Regards,
    Rashed Basuleman
  • 4.  RE: License issue
    Posted Jan 18, 2023 10:45 AM
    I did have these 2 part license on a seperate controller at one point and they worked fine for the wids/wips, The single 7240xm is running AOS8.6, no mobility conductor. I just dont want to lose these license because of the way Licensing is done now.
  • 5.  RE: License issue
    Posted Jan 18, 2023 10:44 PM
    Dear Dustin,
    Please reply if you have any documentation for deployment and testing of WIPS?
    Best Regards,
    Rashed Basuleman
  • 6.  RE: License issue
    MVP GURU
    Posted Jan 19, 2023 06:54 AM
    This what your looking for?
    https://www.arubanetworks.com/assets/tg/TG_WIP.pdf
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 7.  RE: License issue
    Posted Jan 19, 2023 07:00 AM
    Dear  Dustin,
    If you have any other documents you can share .
    Best Regards,
    Rashed Basuleman
  • 8.  RE: License issue
    MVP GURU
    Posted Jan 19, 2023 07:05 AM
    https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/wireless-intrus-prev/wip.htm
    Dustin Burns
  • 9.  RE: License issue
    Posted Jan 19, 2023 07:20 AM
    Thanks Dustin....
    Best Regards,
    Rashed Basuleman
  • 10.  RE: License issue
    Posted Jan 30, 2023 08:58 AM
    Would appreciate if anyone else has ran into this could give some advice.
  • 11.  RE: License issue
    Posted Jan 31, 2023 09:38 AM
    Seems this discussion was hijacked with some out of context questions.
    In AOS8 (like in AOS6), the licenses on a single controller should 'add up' and are capped on the lowest number of assigned licenses.
    Few examples:
    100 AP + 100 RFP + 100 PEF =effective=> 100 AP + 100 RFP + 100 PEF
    100 AP + 100 PEF => 100 AP + 100 PEF
    100 AP + 100 PEF + 3 RFP => 3 AP + 3 PEF + 3 RFP
    If you have a mobility conductor, you can use license pools to assign licenses from a pool to a specific controller, but still on that controller the same logics apply. If you just have 2 WIPS/RFP licenses, those will need to be on a separate controller because of this.
