Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
This thread has been viewed 168 times
  • 1.  Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Oct 06, 2022 07:21 AM
    I experience strange behavior I our conductor/controller/Eduroam environment,
    There are logon problems, and MS Teams cut off trouble.
    The logon is rejected numerus times, all on MS window, Ios, and Android devices,
    before one successful.
    Some MS Teams works flawless for the duration of the call.
    Some AP's blink with orange led…
    Anyone !
  • 2.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Oct 09, 2022 06:17 PM
    You could have any number of issues.  I would type "show log system 50" and see if anything there stands out.
  • 3.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Oct 10, 2022 09:06 AM
    Thank you, this is logging every other second?
    Oct 10 14:55:33 2022 :316041: <5994> <WARN> |wms| SQL Command at function sqldb_add_probe line 1274 \"UPDATE probe_table SET (ip, lms_ip, type, phy_type, ap_type, power_level, ext_ant, name, wired_mac, serial_no, strap, ht_type, phy_num, status, x_coord) = (...) WHERE mac=*\" failed. Reason: PGRES_FATAL_ERROR
  • 4.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Oct 18, 2022 10:23 AM
    I have identified this to be related to only AP-655,
    and Teams calling one to one. (Teams meeting ok)
    On a one to one call, an extreme packed loss,
    and connection failures is experienced.
    It is on all SSID's, intra ssid, or from one to one-other
    Anyone else ?
  • 5.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Oct 18, 2022 10:31 AM
    What clients?
    When you ping that client from the wired network when not on a call, do you get ping drops?
  • 6.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Oct 18, 2022 11:34 AM
    All clients, win10/11, Ios, Android, no ping loss, and no other application with problems.
    And duly noted, at Microsoft (Teams admin center)
    Error
    Other Aruba AP
    OK
  • 7.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 03, 2022 10:38 AM
    After upgrading from OS 8.10.0.2 LSR_84367;
    MS Teams One to One and Skype for Business calls gets cut off with massiv packet Loss.
    Rendering a call impossible.
    The error is when connected to any Aruba AP-635 & 655, ax or ac connection,
    and 5 & 6 Ghz, windows 10/11 and any Ios and Android.
    Anyone...!
  • 8.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 03, 2022 10:46 AM
    Please open a technical support case.  You could have a unique or known issue.
  • 9.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 03, 2022 10:51 AM
    It's done
  • 10.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 03, 2022 12:37 PM
    What model ArubaOS did you upgrade from?  What model controller are you using?  Also, do you have a specific ACL you are using in user's traffic?  Did you add the built in voice acl added to that role?
  • 11.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 04, 2022 03:31 AM
    >"After upgrading from OS 8.10.0.2 LSR_84367";
    therer a two 7210 and no acl.
  • 12.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 16, 2022 11:14 AM
    We are experiencing similar issues with 8.10.0.4. We currently have an open case that has been escalated to engineering. With Teams one to one calls we get a delay starting (around 11 seconds) with no issues on conferences calls generally, users to report teams experience being "rubbish". With skype for business we get one way audio and the call drops after around 30 seconds or so; the captures we sent over to Aruba TAC have shown the packets being sent over the air to the client but their not in the client packet capture. Oddly when the client has one way audio they also can't access dropbox.com!
    We have this issue on both 515 and 535 APs. We found yesterday that a 303h AP connected to the same controller doens't have the issue.
  • 13.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 16, 2022 07:39 AM
    Thank you all,
    Yes yesterday I had a whole day with tac
    aviating report, but no change, however it revealed that the problem
    extended to series 5xx as well.
    Only when under coverage of 2xx/3xx, Teams calls are flawless.
  • 14.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 16, 2022 09:38 AM
    Do you have 802.11r or 802.11k configured on your APs?
  • 15.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    We have also had similar problems and have logged a support call (5368563260). We have experienced these problems with 505H,515 and 535 AP on campus but found yesterday that an AP303H worked ok.
    Have TAC offered any advice yet ?
  • 16.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 16, 2022 11:35 AM
    No other than stating a lot off small packed (UDP), at the clients; are observed,
    Most of the packet length is below 600  on a 655; and above 1000 bytes when it is connected to working AP(2xx/3xx)
  • 17.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 16, 2022 12:27 PM
    Well, since you are already connected with support, you are in the best hands.  Please keep us up to date.
  • 18.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 17, 2022 09:45 AM
    Hi Steinar
    Just to keep you updated with our TAC case, The latest high level fix for us, has been to turn off AirSlice.Engineering are still working on the finer details. I believe the TAC engineers working on our case have looked at your case and have exchanged details
    Cardiff University
  • 19.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 17, 2022 10:28 AM
    Hi, thank you for update,
    One more day with Tac, no changes or good news.
    Upgraded the Cluster to: 8.10.0.5_85552,
    Same massiv packet loss, and termination off calls..
  • 20.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 17, 2022 10:58 AM
    Regarding: AirSlice
    From the manual:
    The 650 Series and 630 Series access points have the following limitations:
    No Hotspot and AirSlice support on the 6 GHz radio
    From 8.9 manual:
    The 630 Series access points (AP-635) support Air Slice on the 5 GHz radio band only
    I tested a call on pure 6Ghz, same result, massiv packed and Round Trip Times.
  • 21.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 17, 2022 04:48 PM
    Our testing this evening with disabling AirSlice on one ap-group in our production enivorment, has not been as sucessful as we would have hoped. Only a slight improvement.
    We need to investigate the other recent changes we have made in our testing lab to see if these changes also need to be added to production.
    We were asked to make changes to the ssid profile as detailed below. Changing these on a couple of AP in a  lab is different to changing our 7K+ live network, so some care will need to be taken to make changes.
    We have a few more testing plans to go back through tomorrow,which we skipped today when we thought we could just disable airslice and fix everything.
    wlan he-ssid-profile <name>
    no he-mu-mimo
    no he-txbf
    wlan ht-ssid-profile <name>
    no vht-mu-txbf-enable
    no vht-txbf-explicit-enable
    Thanks for testing 8.10.0.5 :-) , we had a quick look through the release notes and could not see any references to anything like this issue.
    Cardiff University
  • 22.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 18, 2022 09:07 AM
    Further to Simon's message we have retested this morning. Airslice is most definatly breaking it, our test in production shows teams/sfb issues mostly resolved. We still have delayed start to video in teams. It may be worth turning off airslice for an AP group as a test. Just got off a call with engineering and they have lots more logs to look over. One of the TAC engineers we are working with has also recreated the issue.
    airslice-profile "Disabled"
    ap-group "XXXX"
  • 23.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 18, 2022 09:37 AM
    Ok, but I don't see the logic.??
    [mynode] (config) #sh airslice-profile
    airslice profile List
    Name References Profile Status
    default      2
    [mynode] (config) #sh airslice-profile default
    airslice profile "default"
    Parameter Value
    airslice-app-monitoring Disabled
    airslice-policy                  Disabled
    ([mynode] (config) #ap-group ap-group
    ([mynode] (AP group "ap-group") #show airslice-profile default
    Parameter Value
    Am I missing someting ?
  • 24.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 18, 2022 09:46 AM
    Nope it looks like yours is disabled, unless there are other AP groups or profiles further down the hierarchy on the MM? It looks like you are on the MM node configuration.
    We have a test and development enviroment, we called out from SfB and had one way audio. As soon as we reconnected after applying an disabled airslice profile it started working. Reversed this and it worked.
    If I run the commands on one of the mobility devices I get the following showing it is enabled by default :-
    (XXX) #show airslice-profile default
    Parameter Value
    airslice-app-monitoring Enabled
    airslice-policy Enabled
  • 25.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 18, 2022 09:56 AM
    The only place to run this is on the MM
    [md] #show airslice-profile default
    The commands for applications run on MM need to be executed on /mm tree.
    and from yesterday:
    "The 650 Series and 630 Series access points have the following limitations:
    No Hotspot and AirSlice support on the 6 GHz radio"
  • 26.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 18, 2022 10:00 AM
    Maybe a different problem than ours. The airslice-profile command can be run from the managed devices as well.
  • 27.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Dec 01, 2022 10:52 AM
    Sorry for my assertiveness, TAC instructed, and disabled air-slice at the Managed network level, and Teams call once again is working :)
    This is to be a workaround; I understand work is in progress.
    The reason for the calls working all other places than in a 5xx/6xx AP,
    is that older model is not utilizing air slice at all…
  • 28.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 29, 2022 05:20 AM
    Hi Steinar,
    Did you get anywherre with your issue?
    Our users seem to be reporting that things are a lot better now. A bugfix has been identified and will hopefully get put into future code, not sure which version yet.
    Cheers,
    Mike
  • 29.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Nov 29, 2022 05:25 AM
    Good news for you then :)
    I am hearing nothing!  sic !
  • 30.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Mar 17, 2023 05:33 AM
    Was this reintroduced in 8.10.0.6 ??, even when the issue was mitigated with a workaround to take out ear-slice was/are in place ?
    And the issue was to be found in release note under : Table 6: Resolved Issues in ArubaOS 8.10.0.6
    • AOS-239662 Some clients experienced issues with audio transmission during
      Skype and Microsoft Teams calls. The fix ensures that the clients do
      not experience issues with audio transmission. This issue was
      observed in APs running ArubaOS 8.10.0.4 or later versions.
    It now seems to be reappearing, specially between SSID's/network's/VLAN's..
    (eg. Employee and guest)
    Tested for now under Ap-655 (ax), not any ac.
    Anyone ?, please…
    Steinar
  • 31.  RE: Logon/MS Teams problems after upgrading to 8.10.0.4_85105. on sep. 30.
    Posted Mar 17, 2023 05:35 AM
    Not looking good..Wireshark on client
    Steinar
