Cloud Managed Networks
Managed switches on aruba central importing question
  • 1.  Managed switches on aruba central importing question
    Posted 16 days ago
    Hello i would like to know if you already have a group with this settings
    Let say the group is called Aruba-CX-Switches
    i already have 5 switches in there and i need to move 2 more switches that were not in central, but already have config with the retain config feature?
    Will it retain the config and it will not affect the other  5 switches config that i already have in the Aruba-CX-Switches group?
  • 2.  RE: Managed switches on aruba central importing question
    Posted 15 days ago
    Hello!
    When you first connect a switch to central, you can move the switch to the UI Group and with ONLY* CXs you can select "retain configuration"
    This will keep the current configuration, however to be safe I'd recommend backing up the configuration. lol.
    With AOS-S, it will over-write the current configuration.
