Mesh link and ethernet port bridging question - AP-367s and AP-335
  • 1.  Mesh link and ethernet port bridging question - AP-367s and AP-335
    Posted Mar 08, 2024 09:05 AM
    Hello-
    I come from the controller side of wireless but need to dip my toes into IAP.  I've been tasked with deploying a mesh link to extend a network connection to another building.  I'll be using (2) AP-367s for the mesh, and one of the AP's will be the Primary controller & Mesh-portal in the IAP cluster.  The 2nd AP-367 will be the Mesh-point and will have it's Ethernet port set to bridging mode and connected to a non-managed switch.  On that switch will be an AP-335 to serve clients inside.  Simple pic of topology:
    My question is regarding this note:
    Will I be able to accomplish my goal here, or is this just a limitation when the "Mesh-point" E0 port is not set to "Bridged Mode"?  I'm getting ready to lab this before deployment so I thought I would ask in advance.
    Matt
  • 2.  RE: Mesh link and ethernet port bridging question - AP-367s and AP-335
    Posted Mar 08, 2024 10:51 AM
    The restriction is that you can't have a single VC managing IAPs on both sides of a mesh that is also part of the cluster.
    My recommendation:
    • Configure both of the AP-367 as standalone and use either the clusterless mesh or mesh profile to configure mesh.
    • The 335 can be standalone or cluster; if there is an IAP VC already behind the mesh portal then the 335 can be part of that cluster.
    Carson Hulcher, ACEX#110
  • 3.  RE: Mesh link and ethernet port bridging question - AP-367s and AP-335
    Posted Mar 18, 2024 09:26 AM
    Carson-
    I finished up the project last week.  With your suggestions and some reading of the IAP Manual, I set up the network to comprise of:
    • VC1 and MESH:  Mesh AP's and a bridged Ethernet port
    • VC2:  Standalone AP and DHCP server for client WLAN
    • Aruba Instant ON unmanaged switch for L2
