Hi Jonlar,
Very funny and strange, do you have make a packet capture ?
I think, it will be better to post an iusse on Github aos cx Ansible => https://github.com/aruba/aos-switch-ansible-collection
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jul 25, 2023 06:49 AM
Subject: Missing parts of config when using aoscx_backup_config
I'm using aoscx_backup_config to store the configuration on a tftp server, but on some 6200 switches I'm missing the first 30 or some lines of configuration.
The common thing about the switches where config is missing is that the configuration is copied through an IPsec tunnel.
- name: Copy Running Config to TFTP aoscx_backup_config: config_name: 'running-config' remote_output_file_tftp_path: 'tftp://x.x.x.x/{{ inventory_hostname }}.cli' config_type: 'cli' vrf: "{{ mgmt_vrf | default('mgmt') }}"
The same thing happen if I run the CLI command directly on the switch, but there I can specify a lower blocksize than default, however in Ansible it does not work to do this.
CLI: (this works)
copy running-config tftp://x.x.x.x;blocksize=1000/test.cli cli
Ansible: (this does not work)
remote_output_file_tftp_path: 'tftp://x.x.x.x;blocksize=1000/{{ inventory_hostname }}.cli'
I don't see any way to specify blocksize in Ansible. Is it a missing feature?
