MM Connection issues
This thread has been viewed 19 times
  • 1.  MM Connection issues
    Posted 29 days ago
    We upgraded VMware sphere from 8.0 U1 to 8.0 U2 on 4/21/2024.  Since then the ArubaMM doesn't seem to be connecting with the APs we have. Here is the vm information from "show version" from the VM no-mm console.  There was no change to the VM. Anyone seen something similar? What is the best way to debug?
    VM info
    ArubaOS (MODEL: ArubaMM-VA), Version 8.11.1.0 SSR
    (c) Copyright 2023 Hewlett Packard Enterprise Development LP.
    Compiled on 2023-01-25 at 12:37:03 PST (build 86043) by jenkins
    BIOS Version: Phoenix Technologies LTD, 6.00
    Built: 11/12/2020
    -Switch uptime is 4 minutes 1 seconds
    Reboot Cause: Guest tools Shutdown (Intent:cause: 86:50)
    Supervisor Card
    Processor (s) : pTotal CPUs : 3,
    Sockets: 1,
    Cores Per CPU: 3
    Socket 0: Intel(R) Xeon(R) Silver 4316 CPU @ 2.30GHz
    Ex5703M bytes of memory
    E4096M bytes of Supervisor Card system flash.
  • 2.  RE: MM Connection issues
    MVP GURU
    Posted 29 days ago
    Is there more you could share? You wouldn't be terminating the APs on the Mobility Masters/Conductors either, these should be terminating on Controllers/Gateways.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: MM Connection issues
    Posted 29 days ago
    1. VMware vSphere 8/ESXi 8 isn't supported until AOS 8.12.
    2. Those specs, 3 CPU, "5703M" bytes of memory, are the specs for the MM-VA-50 appliance level.
    How many APs and controllers are in your environment?  What does the output of show inventory and show license platform-limits look like on the Mobility Conductor?
    Carson Hulcher, ACEX#110
  • 4.  RE: MM Connection issues
    Posted 29 days ago
    We have 18APs, Controller, Conductor. The APs and Controller are accessible but conductor is not accessible anymore. We had configured it to have static IP.
    Let me get the show command output and share also.
  • 5.  RE: MM Connection issues
    Posted 28 days ago
    Would you recommend us updating MC to AOS 8.12?
  • 6.  RE: MM Connection issues
    Posted 28 days ago
