Mobility Conductor / Master Webgui admin interface restriction
This thread has been viewed 37 times
  • 1.  Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 06:26 AM
    I've recently found that i can only access the webgui of the Aruba MM from the same subnet as the server. Is this by design? I've been through the hardening guide and the config on the server and can't see any config that is locking it down and wondered if there is a way to open it to an IP outside of its subnet?
    I thought there might be a Web lockdown acl or setting like on clearpass, but can't seem to find it. maybe i'm missing something.
    thanks,
    matt
  • 2.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 08:24 AM
    Could be that something is configured on internal Firewall.
    Do a "show firewall-cp" to investigate
    Reference - https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/firewall-cp.htm
  • 3.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 10:33 AM
    Nothing that i can see. Port 4343 appears to be set to any.
    ipv4        any                     6         4343        4343      Permit            1140205    cpbwc-ipv4-http
    matt
  • 4.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted 28 days ago
    Just to check the basics, the issue is only with the GUI? That is, you can ping and ssh from other subnets, right?
    Steve Bohrer
    IT Infrastructure, Emerson College
  • 5.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 10:47 AM
    If you can reach the WebUI from the same subnet but not from another subnet, it may be as simple as routing; either to the MM or back to your client.
    It's not by design IMHO. I connect to multiple MM WebUIs from a different subnet and never had issues (except for firewalls blocking or routing not in place).
  • 6.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 11:11 AM
    Its strange. I can ping it and i can get as far as it showing me its an untrusted cert (self-gen) and if i hit refresh a load of times quickly i get the logon box, but i can't logon.
    matt
  • 7.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 11:24 AM
    Is your IP traffic passing through a firewall before reaching the MCr? Perhaps blocking 4343?
  • 8.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 11:35 AM
    No direct. Subnet to subnet , No acl.
    matt
  • 9.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted Jul 10, 2024 11:53 AM
    Can you SSH to the MM from the other subnet?
    What about accessing a different device on the same subnet as the MM from the other subnet?
    Have you tried different browsers?
  • 10.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted 30 days ago
    Yes, SSH works fine and is stable.  Can ping from both sides. Tried Chrome, Edge and Firefox. Just had a two hour TAC sessions and they can't work it out either and have taken a diagnostic log.
    matt
  • 11.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted 30 days ago
    What version is on the MCr?
  • 12.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted 29 days ago
    8.10.0.11
    matt
  • 13.  RE: Mobility Conductor / Master Webgui admin interface restriction
    Posted 29 days ago
    Thanks. As far as I can tell, there are no related patches added in 8.10.0.12 or 8.10.0.13 where an upgrade may help fix your problem. This sounds like a bug if not a routing / firewall issue between subnets.
