Hello guys
I got a few questions regarding this mode
I configured a group with monitor only
As you can see its on read only
And it says so as well here
Now i see that can still configure the switch on the aruba central but through the console option in the tools opton
Was this option available to do this? even if its on monitorin mode?
I wonder if the configuration i did is correct? the way you can configure it, its limited just to that console or its the only way i could do it. I saw also that i could create a vlan locally on the switch just do a write memory and it will just show on the aruba central, so i can configure it through the aruba central and also locally.
It was intentional done like this for some reason?
The other question
Its there a way to back up the configuration automatically in monitor only mode? something like the airwave does. that you can see the airwave server with the lastest config and if something happen, you can just go to the airwave and see the last config there, even if its on monitor only
