Cloud Managed Networks
Move device to different site
This thread has been viewed 31 times
  • 1.  Move device to different site
    Posted Jan 19, 2021 05:35 PM
    I have 2 sites setup in Central and I want to move a device from site A to site B but when I go to place it in the site B using the UI I get a 'Site Assignment Error - Can't assign more than 1 site for a device!' is there a way to do this?
    Also, is there a way to delete labels from a device?
    Kind regards
    Brett
    ICT Support
    Leighland Christian School
  • 2.  RE: Move device to different site
    Posted Jan 20, 2021 05:54 AM
    Hi Brett,
    First delete the device from site A. Device(s) will go to unassigned. Now you can add the device(s) to site B.
    For labels the same procedure. Select the label->go to the device section and delete the devices.
    Kind regards
    Sietze
  • 3.  RE: Move device to different site
    Posted May 15, 2024 04:09 PM
    How do you remove a device from a site? This is in the same group with the same vlan mgmt but I have a different site that with same scenario and I was able to move them a while back.
  • 4.  RE: Move device to different site
    Posted 30 days ago
    first you need to go the Global-> Organisation->Site and remove the device from that site.
    generally if you click on "?" and then select documentation centre, it will show you the relevant info.
  • 5.  RE: Move device to different site
    Posted 26 days ago
    Unassign from site A first then assign to site B.
    Give me a Kudo when this is useful.
    Ratchapas
    https://www.facebook.com/Aruba-News-Update-1401095559960142
