Cloud Managed Networks
Multi-Site management Vlan best practice - discussion
  • 1.  Multi-Site management Vlan best practice - discussion
    Posted Feb 08, 2024 07:15 AM
    So one vlan across all sites for the management lan or one management lan per site?
    What are the swings and round abouts?   What is "best practice"?
  • 2.  RE: Multi-Site management Vlan best practice - discussion
    Posted Feb 09, 2024 06:58 AM
    If sites are fully isolated (L2), then having the same VLAN scheme for each of your sites sounds fine.
    It also depends a bit how complex your sites are; not sure if there is a single best practice, however sharing VLAN IDs (or VLAN Names) across different sites will make it easier to share policies that put clients in a specific VLAN.
