Need Clearpass Endpoint IP Address
This thread has been viewed 23 times
  • 1.  Need Clearpass Endpoint IP Address
    Posted 23 days ago
    We are using ClearPass for WIFI SSID authentication(EAP-TLS). Need to capture the endpoint IP address . Can anyone share the procedure and any configuration need to be added in ClearPass.
  • 2.  RE: Need Clearpass Endpoint IP Address
    Posted 23 days ago
    Hi
    You need to enable Radius Accounting to get this information. Radius Accounting are using port UDP 1813 by default.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: Need Clearpass Endpoint IP Address
    Posted 23 days ago
    Is there be any impact for enabling the radius accounting on wlc and in clearpass ?
  • 4.  RE: Need Clearpass Endpoint IP Address
    Posted 22 days ago
    Nothing that hasn't been accounted for.  Accounting is a normal operation that most operators are going to enable.
    Carson Hulcher, ACEX#110
  • 5.  RE: Need Clearpass Endpoint IP Address
    Posted 22 days ago
    Enabled the radius accounting and now able to see the IP Address in the accounting tab. If I need to search a endpoint by a IP address how to do achieve this ?
    Because couldn't see the Endpoint attributes option in the access tracker .
  • 6.  RE: Need Clearpass Endpoint IP Address
    Posted 21 days ago
    You can create a report using Insight, but searches within ClearPass' Access Tracker (or pretty much any RADIUS server for that matter) is going to be around MAC address and username, not follow-on attributes like IP addresses.
