Aruba Apps
last person joined: 11 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Not able to connect. Error code 8949
This thread has been viewed 51 times
  • 1.  Not able to connect. Error code 8949
    Posted Nov 01, 2019 06:41 AM
    I'm using the Virtual Intranet Access application to connect (v. 3.0.0.0.87840) on Windows 10 and keep getting error code 8949. I can download my profile without any issues. This only happens on my work network and works fine on my home network.
    Logs says: "Failed to establish secure connection". and "Remote server connection....Disconnected".
    I have tried to reinstall app and recreating my profile.
  • 2.  RE: Not able to connect. Error code 8949
    MVP GURU
    Posted Mar 30, 2020 08:33 AM
    Check your IPSEC PSK configuration. Having multiple PSKs for 0.0.0.0 can cause this type of error.
  • 3.  RE: Not able to connect. Error code 8949
    Posted May 17, 2022 06:33 AM
    I have this issue too, did you solve it and could you please let me know how have you fixed it?
    Esmail Ayobinia
  • 4.  RE: Not able to connect. Error code 8949
    Posted May 20, 2022 10:53 AM
    If the suggestion to which you responded does not work, I would recommend to reach out to Aruba Support to get your error investigated and resolved. Does not look like a generic issue with generic fix.
  • 5.  RE: Not able to connect. Error code 8949
    Posted May 22, 2022 02:38 PM
    Thank you for your replies.
    Changing the VIA server certificate from default to aruba_default solved the issue.
    Esmail Ayobinia
  • 6.  RE: Not able to connect. Error code 8949
    Posted Jan 02, 2024 10:04 AM
    What version code is your Gateway running @esmailayobinia?  Where specifically is this menu option?
