What is the reported channel utilization on the 2.4GHz?
What are the by ARM selected channels and power for the APs?
Do you have broadcast filtering enabled?
You may try to enable 11d/h, some devices work better with that.
Is it just the ringcam that's giving issues?
What firmware version do you run? Have you upgraded to the latest already?
What is the distance between the device and the AP? You may try to increase the 2.4GHz power to see if that makes the connection better. 57 Mbps link speed can be quite low, depending on the device specifications. Your shelly's report 72 Mbps which seems like the maximum they support.
Original Message:
Sent: Oct 24, 2022 07:52 AM
Subject: Optimize IAP 205 for 2.4Ghz
I have cluster of 5 IAP 205's. I have two SSID's, one with 2.4 and 5Ghz and one IoT 2.4Ghz only. I notice that some devices on the IoT SSID are having stability issues. I think I have set all as optimum as possible, but I would appreciate it if someone can review my config.
