Not sure if you can name your instance aggregate. As far as I know, the aggregate keyword is for show commands to check across different instances.
Maybe
this video may help to get proper configuration on your switch. It's with a different SDN controller, but the switch part should be similar.
Please note that I have not seen Openflow for quite some time. The interest for it seems quite low these days. The feature is great, but has not delivered what everyone hoped from it. With Aruba Dynamic Segmentation/User based Tunnel/Aruba Central Netconductor, you can do similar things in a wider used way.
Original Message:
Sent: Nov 10, 2022 02:17 AM
Subject: Ping not working in HPE Aruba 2930F with Openflow aggregate mode enabled
I have an HPE Aruba 2930F JL259A switch which is used to try out SDN related experiments. But after the aggregate mode instance is enabled , the ping command does not work. It results in "Request timeout out" response.
Aruba-2930F-24G-4SFP(config)# show VLANS
Status and Counters - VLAN Information
Maximum VLANs to support : 256
Primary VLAN : DEFAULT_VLAN
Management VLAN : DEFAULT_VLAN
VLAN ID Name | Status Voice Jumbo
1 DEFAULT_VLAN | Port-based No No
2 OF_CONTROLLER_VLAN | Port-based No No
3 OF_HOST_VLAN | Port-based No No
1. DEFAULT_VLAN (Primary VLAN) - Ports 1-6, IP Address 192.168.10.3 (Default IP: 192.168.10.1)
2. OF_CONTROLLER_VLAN - Ports 7-12, IP Address 192.168.11.1
3. OF_HOST_VLAN - Ports 13-28, IP Address 192.168.12.1
Aruba-2930F-24G-4SFP(config)# show openflow instance aggregate
Configured OF Version : 1.3
Negotiated OF Version : 1.3
Instance Name : aggregate
Data-path Description : aggregate
Administrator Status : Enabled
Member List : VLAN 3
Pipeline Model : Standard Match
Listen Port : None
Operational Status : Up
Operational Status Reason : NA
Datapath ID : 0003187a3b34dee0
Mode : Active
Flow Location : Hardware and Software
No. of Hardware Flows : 2
No. of Software Flows : 1
Hardware Rate Limit : 0 kbps
Software Rate Limit : 100 pps
Conn. Interrupt Mode : Fail-Secure
Maximum Backoff Interval : 60 seconds
Probe Interval : 10 seconds
Hardware Table Miss Count : NA
No. of Software Flow Tables : 1
Egress Only Ports : None
Table Model : Policy Engine and Software
Source MAC Group Table : Disabled
Destination MAC Group Table : Disabled
Default Miss Action : Drop
Packet-In VLAN Tagging : Default
Controller Id Connection Status Connection State Secure Role
1 Connected Active No Equal
I'm using the RYU controller, and the initial handshake connection and configuration from the RYU side with switch seems to working correctly.
Controller IP Address: 192.168.11.2
Aruba-2930F-24G-4SFP(config)# show run
Running configuration:
; JL259A Configuration Editor; Created on release #WC.16.10.0009
; Ver #14:67.6f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:44
hostname "Aruba-2930F-24G-4SFP"
module 1 type jl259a
ip default-gateway 192.168.10.1
snmp-server community "public"
openflow
controller-id 1 ip 192.168.11.2 controller-interface vlan 2
instance aggregate
controller-id 1
version 1.3
enable
exit
enable
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 7-28
untagged 1-6
ip address 192.168.10.3 255.255.255.0
ipv6 enable
ipv6 address autoconfig
ipv6 address dhcp full
exit
vlan 2
name "OF_CONTROLLER_VLAN"
untagged 7-12
ip address 192.168.11.1 255.255.255.0
ipv6 enable
exit
vlan 3
name "OF_HOST_VLAN"
untagged 13-28
ip address 192.168.12.1 255.255.255.0
ipv6 enable
exit
management-vlan 1
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
password manager
Any idea/suggestion as to why this is happening and what can be done would be really helpful, thanks!
