Wired Intelligent Edge
Policy Based Routing Issue in aruba CX
  • 1.  Policy Based Routing Issue in aruba CX
    Posted Jan 12, 2024 07:40 AM
    Hi Airheads,
    I want to migrate a customer's infrastrucute. At the moment the customer has a IRF of 2 x 5950 Comware Switches.
    Now we want to migrate him to a VSX stack of 2 x 8325.
    At the moment we have trouble migrating some special policy based routing (pbr) rules.
    In one VRF there are some VLANs with clients (e.g. 163, 164, ...) and one VLAN as a transfernet (e.g. 1305)  to a firewall system. My customer want like to set up like this:
    Devices from VLAN 163 should not be allowed to communicate DIRECTLY with devices from VLAN 164 but should send all the traffic to the firewall, which regulates the traffic. The same  vice versa, VLAN 164 should not be allowed to communicate DIRECTLY with other VLANs.
    An ACL is not an option, because there are some firewall rules that allow some traffic between those networks.
    At the moment (with comware) we do this with the following commands and the works without problems:
    policy-based-route CUSTOMER_CLIENTS permit node 10
     if-match acl 3501
     apply next-hop vpn-instance CUSTOMER_CLIENTS 172.16.1.65
    acl number 3501 name PBR-VRF-CUSTOMER_CLIENTS
     rule 10 permit ip vpn-instance CUSTOMER_CLIENTS
    interface Vlan-interface163
     ip binding vpn-instance CUSTOMER_CLIENTS
     ip address 172.17.163.254 255.255.255.0
     ip policy-based-route CUSTOMER_CLIENTS
    interface Vlan-interface164
     ip address 172.17.164.254 255.255.255.0
    interface Vlan-interface1305
     ip address 172.16.1.78 255.255.255.240
    Traffic from VLAN 163 and VLAN 164 is always directed to the firewall, independtly of the direct connected routes of the switch.
    Now we are looking for this function in CX and we tried the following:
    sw-core01# show run
    vrf CUSTOMER_CLIENTS
    class ip CL-CUSTOMER_CLIENTS
        vsx-sync
        10 match any any any count
    pbr-action-list PBR-AL_CUSTOMER_CLIENTS
        vsx-sync
        10 nexthop 172.16.1.65
        20 interface null
    policy PBR-CUSTOMER_CLIENTS
        vsx-sync
        10 class ip CL-CUSTOMER_CLIENTS action pbr PBR-AL_CUSTOMER_CLIENTS
    vlan 163
        name 163-CUSTOMER_CL1
        vsx-sync
    vlan 164
        name 164-CUSTOMER_CL1
        vsx-sync
    vlan 1305
        name 1305-CUSTOMER_Trans_CLIENTS
        vsx-sync
    interface vlan 163
        vsx-sync active-gateways policies
        vrf attach CUSTOMER_CLIENTS
        ip address 172.17.163.251/24
        active-gateway ip mac 00:00:01:00:00:02
        active-gateway ip 172.17.163.254
        apply policy PBR-CUSTOMER_CLIENTS routed-in
    interface vlan 164
        ip address 172.17.164.251/24
        active-gateway ip 172.17.164.254
    interface vlan 1305
        ip address 172.16.1.76/28
        active-gateway ip 172.16.1.78
    ip route 0.0.0.0/0 172.16.1.66 vrf CUSTOMER_CLIENTS
    sw-core01(config-policy)# show ip route vrf CUSTOMER_CLIENTS
    Displaying ipv4 routes selected for forwarding
    VRF: CUSTOMER_CLIENTS
    Prefix              Nexthop          Interface     VRF(egress)       Origin/   Distance/    Age
        Type      Metric
    0.0.0.0/0           172.16.1.66      vlan1305      -                 S         [1/0]        06d:21h:25m
    172.16.1.64/28      -                vlan1305      -                 C         [0/0]        -
    172.16.1.76/32      -                vlan1305      -                 L         [0/0]        -
    172.17.163.0/24     -                vlan163       -                 C         [0/0]        -
    172.17.163.251/32   -                vlan163       -                 L         [0/0]        -
    172.17.164.0/24     -                vlan164       -                 C         [0/0]        -
    172.17.164.251/32   -                vlan164       -                 L         [0/0]        -
    192.168.10.0/24     172.16.1.66      vlan1305      -                 S         [1/0]        06d:21h:11m
    Total Route Count : 8
    sw-core01(config-policy)# show pbr summary
    VRF
          Port
                    Policy
                              Class
                                        PBR
                                               Sequence  Type             Nexthop
    CUSTOMER_CLIENTS
          vlan164
                              CL-CUSTOMER_CLIENTS
                                                     10  nexthop          172.16.1.65 (active)
          vlan163
                              CL-CUSTOMER_CLIENTS
    When we now send traffic from a Client in VLAN 163 to anywhere in the internet, the traffic is correctly routed to the firewall. But when the client tries to reach a destination in VLAN 164, the traffic does not passes the firewall but is routed directly to VLAN 164. It seems that the "nexthop" action is ignored, when there is a directrly connected network? Or do we have a configuration problem?
    Has anybody an idea who to solve this problem?
    Thank you!
    Steffen
  • 2.  RE: Policy Based Routing Issue in aruba CX
    Posted Jan 15, 2024 06:48 AM
    Is your PBR configuration identical on both VSX physical nodes and applied ?
  • 3.  RE: Policy Based Routing Issue in aruba CX
    Posted Jan 15, 2024 03:35 PM
    Thanks for your reply. Yes, both of the switches are identical configured. The problem also occurs when one of the VSX-devices is turned off and only one is active.
    Steffen
  • 4.  RE: Policy Based Routing Issue in aruba CX
    Posted Jan 16, 2024 07:14 AM
    No configuration mistake that I can spot out. For better focus and resolution, I would suggest contacting TAC.
  • 5.  RE: Policy Based Routing Issue in aruba CX
    Posted Apr 26, 2024 11:19 AM
    Any update on this?  Was TAC able to help?  We have a pair of 8400s and realized there was a problem with PBR years ago.  TAC came to no conclusions.  We worked around it.  We just recently realized that traffic coming into the secondary VSX switch was not going through policy evaluation at all:  not just PBR.  If we shut down the half of the mlag going to the secondary switch everything is right. If we shut down the half of the mlag going to the primary, traffic continues to flow, but no policies are applied at all.  We tried it with active gateways, independent SVIs, shutting the interfaces to see if it was related to the interface.  Everything right if the traffic enters the primary, but no policy applied if the traffic comes directly into the secondary VSX switch.
