Policy Profile RADIUS: Port Bounce not working Aruba 2530
  • 1.  Policy Profile RADIUS: Port Bounce not working Aruba 2530
    Posted Jun 21, 2022 11:01 AM
    Hello everyone,
    I have configured clearpass in the last few days and it works exactly as described.
    The policy for the mac authentication which sets the vlan to 180 works.
    I still need a port bounce for re-authentication.
    Radius: HPE / HPE-port-bounce-host = 12
    Unfortunately nothing happens at the switch except that the vlan is set.
    Thanks everyone
    -Swagsy
  • 2.  RE: Policy Profile RADIUS: Port Bounce not working Aruba 2530
    MVP GURU
    Posted Jun 21, 2022 04:20 PM
    How is your device set up under Devices? Have you tried to toggle between Aruba or HPE?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Policy Profile RADIUS: Port Bounce not working Aruba 2530
    Posted Jun 22, 2022 02:40 AM
    Yes, tried both.
  • 4.  RE: Policy Profile RADIUS: Port Bounce not working Aruba 2530
    Posted Jun 21, 2022 10:11 PM
    in Cisco switch, termination action value is set to 1 to be able to do reauthentication.
    maybe you can try this ?
  • 5.  RE: Policy Profile RADIUS: Port Bounce not working Aruba 2530
    Posted Jun 22, 2022 02:43 AM
    As the Aruba documentation says this value 12 means the time between the port is shutdown and enabled.
    You need to set a value between 1-59.
    I tried 1 and 59.
  • 6.  RE: Policy Profile RADIUS: Port Bounce not working Aruba 2530
    Posted Jun 22, 2022 02:45 AM
    Heres a little update:
    While configuring the port bounce in the policy its working fine.
    The port bounce is not triggered from the service CoA.
  • 7.  RE: Policy Profile RADIUS: Port Bounce not working Aruba 2530
    MVP EXPERT
    Posted Jun 22, 2022 03:55 AM
    Make sure switch type is HPE for starters
    A
    Sent from my iPhone
  • 8.  RE: Policy Profile RADIUS: Port Bounce not working Aruba 2530
    Posted Jun 22, 2022 06:24 AM
    Ntp at switch & clearpass side is also needed for radius CoA
