Wired Intelligent Edge
last person joined: 41 minutes ago
polycom phone issues with 2930 and cppm monitor mode service
  • 1.  polycom phone issues with 2930 and cppm monitor mode service
    MVP EXPERT
    Posted 9 days ago
    Got a strange issue with polycom phones
    cppm  6.11.8
    2930 switch WC.16.11.13
    Switch port voice vlan configured on vlan 8xx,  data vlan on. vlan  2xx,  switch port  configured to have untagged vlan 2xx tagged vlan  8xx.
    switch  configured to use local and  downoadable user roles. default user-role  is called initial-role and is basically an allow all.
    switch also configured for dot1x and mac auth
    At the cppm end an auth is serviced by a service enabled to  run in monitor mode....
    ..so at the switch end. you see DCA 5204 errors ( im expecting a DUR but you arent giving me anything.) which is correct,
    Whe the phone 1st powers up its on the  untagged vlan ... 8 hours later phone resets and ends up on the  tagged vlan.
    dhcp options on voice vlan  ( 160and 161) used to configure  phone when its on. vlan 8xxx
    all network reauths are set to be 1 hour .. and in cppm i can see successful reauths  every hour.
    Switch authentication off for the phone switch ports and. stuff works
    on the phone however we are still seeing resets evert 8 hours
    Anyone else seen issues with polycom phones on  user-role authenticated switch ports ?
    A
    thc
  • 2.  RE: polycom phone issues with 2930 and cppm monitor mode service
    Posted 9 days ago
    Hi Alex.
    This 8 hour reset window looks more like phone feature than switch/cppm issue.
    Didn't see this behaviour on 2930 nor 2530 switches with polycom phones.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 3.  RE: polycom phone issues with 2930 and cppm monitor mode service
    MVP EXPERT
    Posted 9 days ago
    Hi
    Yup it only seems to be a feature of older phones , we have an estate across multiple sites same switch , same firmware same config and it's only 1 site having issues.
    With a tagged/untagged setup the phone 1st stays on the untagged vlan, then 8 hours later resets and flips to the tagged vlan
    Agree the 8 hours must be a phone thing
    Investigations continue
    A
    Sent from my iPhone
