Developer
last person joined: 7 days ago
Problem with CSRF Token - Aruba Central API
This thread has been viewed 16 times
  • 1.  Problem with CSRF Token - Aruba Central API
    Posted May 25, 2023 09:56 AM
    Hello!
    I'm having trouble making an Aruba Central API call. I want to make a call where I can add a device knowing its mac and its serial number.
    I have two problems in the Aruba API (https://eu-apigw.central.arubanetworks.com/swagger/apps/nms/) there are two categories where I can make this call.
    1.- The first is in 'New Device Inventory' --> Add device using Mac and Serial number. It is a POST call with the following URL: 'https://eu-apigw.central.arubanetworks.com/platform/device_inventory/v1/devices' and the error returned is the following:
       "error_code": 500,
       "msg": "Internal Error - Remote Service"
    2.- On the other hand, we have another category in which to use this call which is 'Deprecated Device Inventory' --> Here I use the URL: 'https://eu-apigw.central.arubanetworks.com/device_inventory/v2 /devices' as indicated in the steps, but I get a different error:
       "error": "CSRF token missing or incorrect.",
       "status_code": 400
    The problem is that I think the one that works well is number 2 (Deprecated Device Inventory). The thing is that I have followed the steps of the following documentation (https://developer.arubanetworks.com/aruba-central/docs/api-oauth-access-token) and I have obtained the CSRF Token, the session, the auth code and the final access token and the refresh token, but it still doesn't work for me and it always says: "CSRF token missing or incorrect.".
    So, I don't know which of the two options I have to use and I don't know how to solve either of the two options. All calls are made from Postman and from my application. The problem is in these calls since I have tried to make calls such as creating a group and it works correctly both from Postman and from my app.
    Thank you very much in advance everyone and I hope it can be solved!
  • 2.  RE: Problem with CSRF Token - Aruba Central API
    MVP GURU
    Posted May 25, 2023 11:01 AM
    What code do you are using ?
    you can look PowerArubaCL, there is already (only) this function for Get Devices (Inventory) and also add Device Inventory
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Problem with CSRF Token - Aruba Central API
    Posted May 25, 2023 11:21 AM
    Hello!
    Thank you very much for answering. The tool is great!
    The thing is that I am programming a mobile application, so I need to make calls to an api with a post method to upload the aruba devices by serial number and mac. In this case, the tool is separate, correct? So I can't use it in my app because I can't make a call to the tool :(.
    Thanks in advance!
  • 4.  RE: Problem with CSRF Token - Aruba Central API
    Posted Jun 02, 2023 12:39 PM
    @alexcv  can you share what your POST payload is with each command? you can change any sensitive information
    Ti Chiapuzio-Wong (they/them)
    HPE Aruba Networking
