Problem with some macOS devices disconnecting and then blacklisting
This thread has been viewed 41 times
  • 1.  Problem with some macOS devices disconnecting and then blacklisting
    Posted Aug 15, 2022 01:48 PM
    Hi all,
    - We have a pair of Mobility Controller 7205 running os 8.7.1.3_79817, it is managed by the Mobility Master device.
    - We use Clearpass for user authentication 802.1x. MacOS devices not join in AD.
    - We had an issue where some MacOS devices automatically disconnected after connecting for about 1 minute and were blacklisted on Mobility Master but We still have other MacOS devices connected successfully and working fine
    + Authentication on clearpass is successful and device connected
    + After 1 minute, device automatically disconnects with no reject log on Clearpass
    + When I try to check the logs with the command 'show client trail info' on disconnected devices, I see the device is roaming even though I'm not movin, Reason is Sta has left and is disassociated, Alert is denied and Blacklisted
    Please help me,
    Thanks.
  • 2.  RE: Problem with some macOS devices disconnecting and then blacklisting
    Posted Aug 15, 2022 04:23 PM
    If you can see the blacklist reason while they are in the blacklist, we can take it from there.
  • 3.  RE: Problem with some macOS devices disconnecting and then blacklisting
    Posted Aug 16, 2022 12:31 AM
    Thanks for the early reply,
    I don't know how to find the blacklist reason.
    I tried to check the log with the 'show ap client trail-info' command of the disconnected device, I see the device is roaming even though I'm not moving, Reason is Sta has left and is disassociated, Alert is denied and Blacklisted.
  • 4.  RE: Problem with some macOS devices disconnecting and then blacklisting
    Posted Aug 17, 2022 05:17 AM
    Check the denylist/bl reason with this: https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/sh-ap-bl-clnt.htm
  • 5.  RE: Problem with some macOS devices disconnecting and then blacklisting
    Posted Aug 19, 2022 03:52 AM
    Thank Cjoseph,
    Thank Herman Robers,
    Blacklist reason is user-define.
    I have searched for information regarding this reason, but I can't find anything.
    Please help me, what should I do next?
  • 6.  RE: Problem with some macOS devices disconnecting and then blacklisting
    Posted Aug 19, 2022 05:13 AM
    See here where denylisting may come from. Not sure if Authentication failures or Firewall driven show up as user-defined... but it looks like someone intentionally configured this.
    With the behavior that users can connect and are disconnected after about a minute, I would have a look at your firewall policy first, then IDS.
    It may be good to have a look with Aruba support to go through the logs and configuration to see where this is coming from.
  • 7.  RE: Problem with some macOS devices disconnecting and then blacklisting
    Posted Aug 19, 2022 07:54 AM
    type "show log security all" and see if there are any messages related to blacklisting.
