Problems with roaming between SSIDs
This thread has been viewed 37 times
  • 1.  Problems with roaming between SSIDs
    Posted May 30, 2023 01:25 PM
    hello everyone,
    Can you help me with a problem that I have in my Access Point 515 cluster, users are presenting a disconnection of the SSID that they are connected to and according to what I have verified with the Artificial Intelligence offered by Aruba Central. There is a problem with latency when roaming between SSIDs.
    The detail is that I have two networks open without configuring any authentication and the Wireless User network maintains WPA2-PSK authentication.
    I have disabled roaming on the SSIDs that have the network open, but I still have the problem.
  • 2.  RE: Problems with roaming between SSIDs
    Posted May 31, 2023 06:06 AM
    Following CLI Output could be interesting from an impacted AP:
    show clarity history sta
    How are APs deployed? By the result of an Site Survey?
  • 3.  RE: Problems with roaming between SSIDs
    Posted May 31, 2023 12:27 PM
    Thanks for answering cordless
    This is what the command shows me
    The APs are adequately deployed in each site, a previous site survey was carried out to adequately cover the signal.
  • 4.  RE: Problems with roaming between SSIDs
    Posted Jun 01, 2023 05:24 AM
    Looks good.
    What is the Wi-Fi Connectivity Dashboard is saying for the last day?
    From AI InsightI can see there are Coverage Hole Detections. You have to keep that into consideration.
