Original Message:
Sent: Jun 12, 2023 09:36 AM
Subject: PVID Mismatch between HP 5900 and Aruba 2530
Here my results:
<SW001>debug lldp packet receive interface ten
<SW001>debug lldp packet receive interface Ten-GigabitEthernet 2/0/45
<SW001>*Jul 20 02:57:12:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Interface Ten-GigabitEthernet2/0/45 nearest-bridge; Length is 259.
Chassis type : MAC address
Chassis ID : 9460-d5f2-6a0b
Port ID type : Locally assigned
Port ID : 37
Time to live : 120
*Jul 20 02:57:42:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Port ID : 37
Time to live : 120
*Jul 20 02:58:12:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Port ID : 37
Time to live : 120
*Jul 20 02:58:42:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Port ID : 37
Time to live : 120
*Jul 20 02:59:12:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Port ID : 37
Time to live : 120
*Jul 20 02:59:42:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Port ID : 37
Time to live : 120
*Jul 20 03:00:12:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Port ID : 37
Time to live : 120
*Jul 20 03:00:42:022 2011 SWDRNTE001 LLDP/7/Packet received: -Slot=2;
Port ID : 37
Time to live : 120
Here is my spanning tree display result :
<SW001>display stp brief
MST ID Port Role STP State Protection
0 Bridge-Aggregation21 DESI FORWARDING NONE
0 Bridge-Aggregation31 DESI FORWARDING NONE
0 Bridge-Aggregation1001 ROOT FORWARDING NONE
0 Ten-GigabitEthernet1/0/1 DESI FORWARDING NONE
0 Ten-GigabitEthernet1/0/17 DESI FORWARDING NONE
0 Ten-GigabitEthernet1/0/40 DESI FORWARDING NONE
0 Ten-GigabitEthernet1/0/41 DESI FORWARDING NONE
0 Ten-GigabitEthernet1/0/42 DESI FORWARDING NONE
0 Ten-GigabitEthernet1/0/43 DESI FORWARDING NONE
0 Ten-GigabitEthernet1/0/44 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/1 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/17 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/39 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/40 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/41 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/43 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/44 DESI FORWARDING NONE
0 Ten-GigabitEthernet2/0/45 ALTE DISCARDING NONE
Original Message:
Sent: Jun 09, 2023 02:09 PM
Let's reveal the truth. For that I suggest you to use debugging on the 5900:
Open an SSH or Console session to the 5900 and execute following commands one by one:
terminal monitorterminal debugdebug lldp packet receive interface gig2/0/45 verbose
Wait for a minute to get 1-2 LLDP packets from the adjacent switch and disable the debug:
undo debugging all
Then paste the console session's output here and we will see which device is wrong - Aruba sends out incorrect PVID or Comware incorrectly interprets the data received.
Ivan Bondar
Original Message:
Sent: Jun 09, 2023 11:21 AM
Something is wierd, because when I'm doing an show interface brief on the aruba side, the port 1/37 is PVID 12.
The 5900 seems showing this port as PVID 0, this is not normal
Original Message:
Sent: Jun 08, 2023 12:31 PM
Ok, so PVID is 12 on 5900 side and 0 on the ArubaOS side. PVID 0 means that the port 37 on Aruba doesn't carry any untagged traffic and will drop any inbound untagged frames. This could be the reason why traffic from 5900 in VLAN 12 that goes out the port 2/0/45 as untagged doesn't get through. However, that state on ArubaOS switch is really strange, because from what I see in its configuration the port 37 should be untagged in VLAN 12.
BTW, another possible problem - you've got a working LAG (BAGG) between switches and you have another link (that troublesome link in VLAN12) between switches. While VLAN12 is present on either of those links, it's not a problem, there is no danger of a L2 loop, however I'm afraid RSTP that you seem to be using at least on 5900 doesn't know nothing about VLANs, it maintains single STP tree for ALL Vlans and from its perspective that VLAN12 link should be blocked. When you resolve issue on Aruba with PVID 0, please, check STP state of that link on both switches, as one of the sides may block its port.
Ivan Bondar
Original Message:
Sent: Jun 08, 2023 05:24 AM
Hello Ivan
Here are the logs from the 5900:
%Jul 15 06:12:30:411 2011 SWDRNTE001 SHELL/6/SHELL_CMD: -Line=vty0-IPAddr=10.20.12.11-User=admindr; Command is ping 10.20.12.187
%Jul 15 06:12:07:394 2011 SWDRNTE001 LLDP/5/LLDP_PVID_INCONSISTENT: -Slot=2; PVID mismatch discovered on Ten-GigabitEthernet2/0/45 (PVID 12), with SWDRNTE002 37 (PVID 0).
And my conf on the other switch is :
vlan 1
name "DEFAULT_VLAN"
no untagged 1/37-1/42,2/37-2/42,2/45,Trk1
untagged 1/1-1/36,1/43-1/47,1/49-1/51,2/1-2/36,2/43-2/44,2/46-2/47,2/49-2/51
no ip address
ipv6 enable
ipv6 address dhcp full
exit
vlan 12
name "VLAN_MGMT"
ip address 10.20.12.202 255.255.255.0
exit
vlan 202
name "VLAN_SRV"
untagged Trk1
ip address 192.168.20.202 255.255.255.0
exit
vlan 300
name "VLAN_PC"
untagged 2/45
tagged Trk1
no ip address
exit
For the moment the only traffic working between the 2 swtichs is between the BAGG 1001 (HP5900) and the trunk Trk1 (Aruba)
For management purposes, I wanted to connect again the 2 switchs by one wire between the VLAN 12, so between the port Ten 2/0/45 (HP5900) and the 1/37 (Aruba)
Original Message:
Sent: Jun 07, 2023 01:04 PM
Where do you see that PVID mismatch error message - on 5900 or on 2530? Please, double-check the message, because what it says does not match the configuration of the 5900 XGE2/0/45.
As per configuration shared the XGE 2/0/45 has PVID 12:
interface Ten-GigabitEthernet2/0/45 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 12 port trunk pvid vlan 12 broadcast-suppression pps 100
So that error message is misleading. It will help if you paste it here as-is to avoid any misinterpretations. Also you need to check the configuration of PVID on the 2530's side of the link.
Ivan Bondar
Original Message:
Sent: Jun 07, 2023 06:17 AM
Hello
I'm using a an HP5900 with this configuration:
<SW001>display current-configuration
version 7.1.045, Release 2432P06
sysname SW001
clock timezone UTC+1 add 01:00:00
clock summer-time FDT 02:00:00 March last Sunday 03:00:00 October last Sunday 01:00:00
clock protocol ntp
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 32
irf member 2 priority 31
irf mode normal
lldp global enable
system-working-mode standard
fan prefer-direction slot 2 port-to-power
password-recovery enable
vlan 1
vlan 11
name MGMT_001
vlan 12
name MGMT_002
vlan 201
name PRODUCTION_001
vlan 202
name PRODUCTION_002
vlan 300
name PC_002
vlan 4094
description MAD-BFD
irf-port 1/1
port group interface FortyGigE1/0/51
irf-port 1/2
port group interface FortyGigE1/0/52
irf-port 2/1
port group interface FortyGigE2/0/51
irf-port 2/2
port group interface FortyGigE2/0/52
stp mode rstp
stp bpdu-protection
stp global enable
interface Bridge-Aggregation21
description TRUNK_LINK_TO_SVV002_MGMT
link-aggregation mode dynamic
interface Bridge-Aggregation31
description TRUNK_LINK_TO_SVE001
port access vlan 12
interface Bridge-Aggregation32
description TRUNK_LINK_TO_SVE002
port access vlan 12
interface Bridge-Aggregation1001
description LACP_LINK_TO_SW002
port trunk permit vlan 202 300
port trunk pvid vlan 202
interface NULL0
interface Vlan-interface12
ip address 10.20.12.201 255.255.255.0
interface Vlan-interface4094
mad bfd enable
mad ip address 10.99.99.1 255.255.255.0 member 1
mad ip address 10.99.99.2 255.255.255.0 member 2
interface FortyGigE1/0/49
interface FortyGigE1/0/50
interface FortyGigE2/0/49
interface FortyGigE2/0/50
interface M-GigabitEthernet0/0/0
interface Ten-GigabitEthernet1/0/1
port trunk permit vlan 12 202 300
interface Ten-GigabitEthernet1/0/2
port trunk permit vlan 1 11 201
interface Ten-GigabitEthernet1/0/3
undo lldp tlv-enable dot1-tlv port-vlan-id
port link-aggregation group 1001
interface Ten-GigabitEthernet1/0/4
interface Ten-GigabitEthernet1/0/5
port access vlan 202
interface Ten-GigabitEthernet1/0/6
interface Ten-GigabitEthernet1/0/7
interface Ten-GigabitEthernet1/0/8
interface Ten-GigabitEthernet1/0/9
interface Ten-GigabitEthernet1/0/10
interface Ten-GigabitEthernet1/0/11
interface Ten-GigabitEthernet1/0/12
interface Ten-GigabitEthernet1/0/13
interface Ten-GigabitEthernet1/0/14
interface Ten-GigabitEthernet1/0/15
interface Ten-GigabitEthernet1/0/16
interface Ten-GigabitEthernet1/0/17
port trunk permit vlan 11 to 12 201 to 202
interface Ten-GigabitEthernet1/0/18
interface Ten-GigabitEthernet1/0/19
interface Ten-GigabitEthernet1/0/20
interface Ten-GigabitEthernet1/0/21
interface Ten-GigabitEthernet1/0/22
interface Ten-GigabitEthernet1/0/23
interface Ten-GigabitEthernet1/0/24
interface Ten-GigabitEthernet1/0/25
interface Ten-GigabitEthernet1/0/26
interface Ten-GigabitEthernet1/0/27
interface Ten-GigabitEthernet1/0/28
interface Ten-GigabitEthernet1/0/29
interface Ten-GigabitEthernet1/0/30
interface Ten-GigabitEthernet1/0/31
interface Ten-GigabitEthernet1/0/32
description "PC MGMT"
interface Ten-GigabitEthernet1/0/33
port link-aggregation group 21
interface Ten-GigabitEthernet1/0/34
interface Ten-GigabitEthernet1/0/35
interface Ten-GigabitEthernet1/0/36
interface Ten-GigabitEthernet1/0/37
port access vlan 12
port link-aggregation group 31
interface Ten-GigabitEthernet1/0/38
port access vlan 12
port link-aggregation group 32
interface Ten-GigabitEthernet1/0/39
port access vlan 12
interface Ten-GigabitEthernet1/0/40
port access vlan 12
interface Ten-GigabitEthernet1/0/41
port access vlan 12
interface Ten-GigabitEthernet1/0/42
port access vlan 12
interface Ten-GigabitEthernet1/0/43
port access vlan 12
interface Ten-GigabitEthernet1/0/44
port access vlan 12
interface Ten-GigabitEthernet1/0/45
port access vlan 12
interface Ten-GigabitEthernet1/0/46
port access vlan 12
shutdown
interface Ten-GigabitEthernet1/0/47
description MAD_LINK
port access vlan 4094
duplex full
undo stp enable
stp edged-port
interface Ten-GigabitEthernet1/0/48
duplex full
undo stp enable
stp edged-port
interface Ten-GigabitEthernet2/0/1
interface Ten-GigabitEthernet2/0/2
interface Ten-GigabitEthernet2/0/3
interface Ten-GigabitEthernet2/0/5
interface Ten-GigabitEthernet2/0/6
interface Ten-GigabitEthernet2/0/7
interface Ten-GigabitEthernet2/0/8
interface Ten-GigabitEthernet2/0/9
interface Ten-GigabitEthernet2/0/10
interface Ten-GigabitEthernet2/0/11
interface Ten-GigabitEthernet2/0/12
interface Ten-GigabitEthernet2/0/13
interface Ten-GigabitEthernet2/0/14
interface Ten-GigabitEthernet2/0/15
interface Ten-GigabitEthernet2/0/16
interface Ten-GigabitEthernet2/0/17
interface Ten-GigabitEthernet2/0/18
interface Ten-GigabitEthernet2/0/19
interface Ten-GigabitEthernet2/0/20
interface Ten-GigabitEthernet2/0/21
interface Ten-GigabitEthernet2/0/22
interface Ten-GigabitEthernet2/0/23
interface Ten-GigabitEthernet2/0/24
interface Ten-GigabitEthernet2/0/25
interface Ten-GigabitEthernet2/0/26
interface Ten-GigabitEthernet2/0/27
interface Ten-GigabitEthernet2/0/28
interface Ten-GigabitEthernet2/0/29
interface Ten-GigabitEthernet2/0/30
interface Ten-GigabitEthernet2/0/31
interface Ten-GigabitEthernet2/0/32
interface Ten-GigabitEthernet2/0/33
interface Ten-GigabitEthernet2/0/34
interface Ten-GigabitEthernet2/0/35
interface Ten-GigabitEthernet2/0/36
interface Ten-GigabitEthernet2/0/37
port access vlan 12
interface Ten-GigabitEthernet2/0/38
port access vlan 12
interface Ten-GigabitEthernet2/0/39
port access vlan 12
interface Ten-GigabitEthernet2/0/40
port access vlan 12
interface Ten-GigabitEthernet2/0/41
port access vlan 12
interface Ten-GigabitEthernet2/0/42
port access vlan 12
interface Ten-GigabitEthernet2/0/43
port access vlan 12
interface Ten-GigabitEthernet2/0/44
port access vlan 12
interface Ten-GigabitEthernet2/0/46
port access vlan 12
shutdown
interface Ten-GigabitEthernet2/0/47
duplex full
undo stp enable
stp edged-port
interface Ten-GigabitEthernet2/0/48
duplex full
undo stp enable
stp edged-port
scheduler logfile size 16
line class aux
user-role network-admin
line class vty
user-role network-operator
line aux 0 1
line vty 0 15
authentication-mode scheme
protocol inbound ssh
line vty 16 63
ssh server enable
undo ssh server compatible-ssh1x enable
ssh user admin service-type stelnet authentication-type password
ntp-service enable
ntp-service source M-GigabitEthernet0/0/0
ntp-service unicast-peer 192.168.21.51
ntp-service unicast-peer 192.168.20.51
ntp-service unicast-server 192.168.21.51
ntp-service unicast-server 192.168.20.51
header motd %
* UNAUTHORISED ACCESS PROHIBITED *
* This system is for the use of authorised users only. Individuals using *
* this computer system without authority, or in excess of their authority, *
* are subject to having all of their activities on this system monitored and*
* recorded by system personnel. *
* In the course of monitoring individuals improperly using this system, or *
* in the course of system maintenance, the activities of authorised users *
* may also be monitored. *
* Anyone using this system expressly consents to such monitoring and is *
* advised that if such monitoring reveals possible evidence of criminal *
* activity, system personnel may provide evidence of such monitoring to *
* security officials. *
* The above notice also applies when using this system, or parts of it, to *
* gain access to other systems. *
radius scheme system
user-name-format without-domain
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash dddd
service-type ssh terminal
authorization-attribute user-role network-admin
authorization-attribute user-role network-operator
return
<SW001>
For the moment a trunk between the HP 5900 and Aruba 2530 is made by the BAGG 1001 and works fine.
On each switch I've got the same vlans. BAGG1001 is mainly allowing traffic to vlan 202.
I wanted to dedicate a port for VLAN 12 between the 2 equipments using the port Ten-GigabiEthernet 2/0/45 on the 5900 and an untagged port from my HP 2530.
Pb is when I plug a wire, I've got no traffic and I can see in logs the message : "PVID mismatch discovered on Ten-GigabitEthernet2/0/45 (PVID 1) and HP2530 1/037 (PVID 12)
Any idea of this behavior ?
regards
