Quick Reference for AP PoE Requirements
  • 1.  Quick Reference for AP PoE Requirements
    Posted 2 days ago
      730 650 630 615 555 535 515 505
    Eth Interfaces 2x5G 2x5G 2x2.5G 1x2.5G 2x5G 2x5G 1x2.5G, 1x1G 1x1G
    802.3af Support   2 Ports, IPM enabled*   IPM       IPM
    802.3at Class 4 (40W) Support IPM IPM IPM X IPM IPM X X
    802.3bt Class 6 (60W) or higher Preferred (no IPM, no restrictions) X X X   X X X
    When PoE power is supplied to both Ethernet ports, Power from both interfaces is combined    X     X X
    When PoE power is supplied to both Ethernet ports, either port can be configured as the active power source Active/Standby X   X
    Only Eth0 supports POE       X     X X
    When powered by 802.3at (class 4) PoE with the IPM feature disabled, the AP will disable:
    USB ports
    2nd Ethernet
    2x2 all radios
    4x4 only 5G radio
    Disable tri-radio
    USB  USB*
    2nd Eth
    2x2 All Radios*
    USB USB USB
    2nd Eth
    4x4 (5G)
    Disable tri-radio
    USB
    2nd Eth
      USB
    Attachment(s)
    xlsx
    AP Power Requirements.xlsx   10 KB 1 version
