Higher Education
Got questions on how to enable mobility in education? Submit them here!
Remote AP Cluster in Aruba 8
  • 1.  Remote AP Cluster in Aruba 8
    Posted Oct 18, 2021 01:54 PM
    Good afternoon
    Based on the RAP documentation do we cluster the controllers the same way clustering mobility controllers but instead of using private addresses I can use public addresses to avoid dealing with one to one NAT at the firewall. So, if I have 2 controllers I will need 4 IP addresses. One for management controller-ip and one for CoA for clearpass in the cluster profile. Also, I need to make sure I create the VLAN pool name at the Master level then configure the ip interface locally at the mobility device level. Am I on the right track?
    Thank you for the time,
    Nils
    Nils Lau
    Nova Southeastern University
    Attachment(s)
  • 2.  RE: Remote AP Cluster in Aruba 8
    Posted Oct 19, 2021 08:17 AM
    It sounds like you're on the right path here.
    Are you proposing to use public IP addresses as controller-ip and COA? You would typically have a cluster Virtual IP address also.
  • 3.  RE: Remote AP Cluster in Aruba 8
    Posted Oct 21, 2021 12:48 PM
    Thank you very much!!
    You are right I need to take into account the VIP too.
    Nils Lau
    Network engineer
    Office of Innovation & Information Technology
    Office (954) 262-4929 | Cell (954) 7707596
    nils(@)nova(dot)edu | nova.edu
    https://www.nova.edu/brand/_images/sig-images/spacer-1x20.gif
    https://www.nova.edu/brand/_images/sig-images/logo-email.png
