just be aware that you also can have an IAP-VPN solution in which you dont require Aruba Central. All you need is Instant APs at remote sites and an existing controller (non-AOS10 )
Original Message:
Sent: Jul 02, 2024 07:22 AM
Subject: remote aps and aruba os 10
Yeah, Aruba in their wisdom decided to axe remote APs in classic wireless setups, so now you need both an extra dedicated gateway in VPNC/branch mode, and an EXTREMELY expensive central license and complicated redundant WLAN configuration in Central to do what RAP used to do.
A total fail for Aruba in my opinion. I had a customer that backtracked on their AOS10 Central decision because of the massive cost and configuration overhead this requires.
Original Message:
Sent: Jun 28, 2024 11:56 AM
Hello
I have Aruba OS 10 with Aruba Central with a foundation WLAN gateway license.
I need to configure a remote AP like we did on the old version 6.x, The AP will be connected to different sites to give wireless to corporate users. This will be not a branch office or anything like that, the AP will be taken to different sites constantly
I want to know if this remote AP config is now what you call microbranch and does it work with the license I have right? the WLAN Gateway license
Carlos
