Cloud Managed Networks
Remote APS and Aruba OS 10
  • 1.  Remote APS and Aruba OS 10
    Posted Apr 20, 2023 05:37 PM
    Hello i was wondering how this works?
    Back in time i used to configured with 6.4 my remote APS and all that, i belaive its the same with aruba OS 8
    But what happens with Aruba  OS10 which the managment is on the cloud, can i do the same with aruba controllers with WLANGAteway license with microbranche?
    I would like the expirience of extending my vlans of the office to my remote sites if that is possible with the same SSID like i used to do with the 6.4
  • 2.  RE: Remote APS and Aruba OS 10
    Posted Apr 21, 2023 01:50 AM
    You will need a VPNC (gateway physical or virtual) in your datacenter. Then configure microbranch on AOS10. There are detailed videos in Airheads channel how to do this.
    Here is the first video in the series SD-BRANCH from scratch.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
