Wireless
Remote APs - TFTP
  • 1.  Remote APs - TFTP
    Posted 27 days ago
    If a Remote AP (RAP) loses its local image, does it use TFTP to download latest image?  If I disable TFTP, will RAP still be able to upgrade when I do a controller code upgrade?
    Peter
  • 2.  RE: Remote APs - TFTP
    Posted 26 days ago
    It should all happen over IPsec.  Generally speaking TFTP would not survive a nat connection.
  • 3.  RE: Remote APs - TFTP
    Posted 25 days ago
    Is it possible to disable TFTP?  Our security team is asking if we can disable it due to it being open to the public
    Peter
  • 4.  RE: Remote APs - TFTP
    Posted 25 days ago
    You should only be allowing UDP 4500 on your firewall for remote APs.
