Wired
Replace faulty module for HP J9850A Switch 5406Rzl2 with running configuration
  • 1.  Replace faulty module for HP J9850A Switch 5406Rzl2 with running configuration
    Posted Mar 26, 2024 02:27 AM
    Hi, can i know the procedure and configuration to replace module for HP J9850A Switch 5406Rzl2 in production environment? How to copy the configuration from active module to standby module? Thank you
  • 2.  RE: Replace faulty module for HP J9850A Switch 5406Rzl2 with running configuration
    Posted Mar 26, 2024 06:01 PM
    Are you replacing a management module or a switch module? What is model number of the module itself?
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
