Cloud Managed Networks
roaming 11v not working?
This thread has been viewed 23 times
  • 1.  roaming 11v not working?
    Posted 17 days ago
    I use two Aruba APs,and configure them with the same SSID name, password and encryption type, and activated the 11k and 11r , but cell phones didn't roam smoothly between two APs,keeping connecting to one AP even if I walkd closed to the other and received RSSI of connected AP is pretty low. So I use wireshark to caputure the wireless packets, however, there's no 11v frame captured, does APIN0555 support 11v? and how can I activate it to assit clients to roam?
  • 2.  RE: roaming 11v not working?
    Posted 17 days ago
    is this for Instant APs? and does your clients support 11v?
  • 3.  RE: roaming 11v not working?
    Posted 16 days ago
    both are yes
  • 4.  RE: roaming 11v not working?
    Posted 16 days ago
    and I haven't found the bottom to enable 11v in AOS 10, is it canceled in OS10 ?
  • 5.  RE: roaming 11v not working?
    Posted 16 days ago
    in AOS10 11v is enabled by default.
    Also note that with AOS8.x IAPs, 11v works with clientMatch  service so you need to enable.
