Q1: If OKC is disabled in the "802.1x authentication profile," but enabled in the "wlan ssid-profile" - which takes precedence?
Q2: Does roaming from band to band (same SSID) on the same AP require a full 802.1x re-auth? (This would be within an 8.9 cluster, with 802.11r/k not enabled, answer to Q1 above determines if OKC is enabled or not)
Q3: What is the AMP client "association history" showing? Is it the low level 802.11 auth + association, but not necessarily when the client fully roamed to that AP (802.11 auth + association + 802.1x auth)? I ask because comparing my ClearPass access tracker entries, they do not line up with the AMP client association history. The AMP client association history shows more entries than I see in access tracker when testing roaming with my test client. So for example: As my test client (windows laptop) roamed, I may see 12 association history events in AMP among 8 different APs, but I only see 4 access tracker entries in ClearPass sourced from 4 different APs.
Q4: In viewing the mobility trail via the cli (#
show ap client trail-info) it seems limited to the last 10 entries. Is there a way to see more via cli? Is the controller cli "mobility trail" the same as the client "association history" displayed in AMP for a client?
