Roaming between ap's on different controllers not working
This thread has been viewed 16 times
  • 1.  Roaming between ap's on different controllers not working
    Posted May 19, 2022 10:27 AM
    setup : two mobility controllers running 8.6.0.13 (controlled by mobility master) in a HA config.  I remarked that when i roamed between two ap's, i had to reauthenticate using clearpass.  When investigating i noticed this only happened when i roamed between ap's which were on different controllers.  When i moved both ap's on the same controller, the issue did not appear.  I'm using roaming on L2.
    wlan virtual-ap "guests-prod"
    aaa-profile "guests-clearpass-prod"
    vlan 1000
    ssid-profile "guests-prod"
    band-steering
    broadcast-filter all
    no mobile-ip
    vlan-mobility
    Is this expected?  Should roaming between ap's on different controllers in a HA group work?
  • 2.  RE: Roaming between ap's on different controllers not working
    Posted May 19, 2022 10:33 AM
    You will have to re-authenticate when roaming between controllers.
  • 3.  RE: Roaming between ap's on different controllers not working
    MVP
    Posted May 19, 2022 12:43 PM
    Is this also the case in a cluster? (not an HA config, but a cluster config)
  • 4.  RE: Roaming between ap's on different controllers not working
    Posted May 19, 2022 10:51 PM
    With a cluster, you should not have that problem.
