if the vlans are trusted, then there will not go through any form of authentication.
Original Message:
Sent: Dec 10, 2023 07:38 AM
Subject: SD-Branch Radius Authentication with CPPM
The port is trusted and the Vlan has the AAA policy attached to it.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/73368a2919a14d5997a47fb2269887a5.png)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/d705a34ca2bb4dd58b138b53feafc102.png)
We have our own auth setup, but I just moved it to default that we set up the same settings to anonomyze
Original Message:
Sent: Dec 09, 2023 07:01 PM
are the VLAN set to untrusted?
Original Message:
Sent: Dec 07, 2023 02:52 PM
Hey Everyone,
I know I am probably missing something small on this. We are working on setting up a new SD-Branch environment, and one of the big things that we have is delivering Vlans/Roles from our CPPM to devices. I seem to be having some issues with the 9000 devices initiating a radius session with the CPPM on plug in. Switch wise you of course set this up per port, but it seems you do this per vlan on the gateway. I have done this, but I am still not seeing any trafffic actually going to the clearpass.
I have servers and server groups set up
I have a custom AAA policy set up
I am using the default MAC auth L2
I have the AA policy applied to all vlans.
Any help would be greatly appreciated
