Sensor wireless EAP-TLS
  • 1.  Sensor wireless EAP-TLS
    Posted 22 days ago
    Hello
    I hope someone can point me in the right direction.
    I have a  UX-G6E Sensor, that i'm trying to setup with EAP-TLS, on a wireless network.
    The wireless network is validating endpoints by machine certificate.
    I created a machine certificate (.pfx), that i tested on a clean installed machine, and it works without any issue on the SSID.
    When i use the same certificate on the UX-G6E Sensor, then it fails with this error:
    Wi-Fi association failed
    [ { "elapsed": 0, "properties": { "State": "disconnected" } }, { "elapsed": 0.008, "properties": { "State": "inactive" } } ]
    Looking through the 802.1x certificate information, the certificate chain looks fine. Dates are valid as well.
    So i'm a bit unsure what i did wrong
  • 2.  RE: Sensor wireless EAP-TLS
    Posted 16 days ago
    Do you have ClearPass as your RADIUS server? The RADIUS server logs may provide you additional information.
    If I'm right, under Advanced you can (should) also set the RootCA that signed the RADIUS server certificate. It may be that the sensor doesn't trust the RADIUS server cert.
